get a service manual for the trikes and start reading
get one started and begin putting the pieces together like a puzzle
good luck and you are in the right place for help just ask more specific questions.
RR
'WHEN IN DOUBT.........GAS IT!'
87 KXT250B2 Tecate
86 ATC250ES BIG RED
85 ATC350X
85 ATC70
'A FEW IN PARTS'
thanks do you have anywhere online i can download a service manual
try clicking the words 'service manual' in your post or:
http://www.3wheelerworld.com/showthr...pdated-9-13-07
(welcome and good luck with the rebuild)
you are in the right place... just ask away as you go, piecce by piece... theyre fairly simple machines
http://www.hondaservicerepairmanual....ervice-manual/
uhhh i can find other links posted here for the pdf files... i need time to find it but try that
1985 Kawasaki Tecate 250 with kx 500cc motor
1985 Honda ATC 70 custom built with lifan 125cc
1985 Honda ATC 70 custom powder coat slight mods
1985 Honda 250sx
Yamaha zinger 90cc 2 stroke
1985 Honda 250sx custom green and black build
1985 Honda 200x
welcome biggwill,
Firdt off change spark plug on the mostly complete motor , oil, and clean the carb. Then you will want to clean the fuel tanks out and pick the best of them all. Next check for spark, if no spark then we can make you a list of solutions if there is then put the plug back in and see if it starts. Here is a link for a downloadable manual http://www.oscarmayer.net/atc/manuals/
I recommend fixing one up and parting the other one out, but it's your choice on how much you want to spend for parts. I don't believe a complete rear end will be very cheap.
thanks guys i plan on getting started on it tomorrow ive got one more question though the key is gone how can i bypass
thanks guys i plan on getting started on it tomorrow ive got one more question though the key is gone how can i bypass it
disconnect it, i heard thats all you would have to do. not totally sure though
if you want a new key made for it take the key switch down to a honda dealer and they should be able to make one for you, otherwise just disconnect it .
ok guys i used a screwdriver to turn the ignition on and i bought a new plug today im not getting any spark from the plug any ideas on what could be the problem from there?
ok today i disconnected the ignition cleaned the carb and cleaned up all the connectors but im still not getting any spark at all im stumped on what to do next
