Results 1 to 11 of 11
Thread: Need help with cleaning real dirty baked on for years kinda plastic....
    Maine
    463
    Just like the title says..I picked up a 1985 yellow Yamaha 200 and the plastic is really blackish tan on parts of the fenders. I tried soap first and a little comet but didnt do much at all. I than tried clorox green in a spray bottle and it took it right of in a small spot but the plastic was roughed up where I used it. Just wandering if there is something special I can use that will not scratch or is this my only option because its been caked on too long....Thanks for reading..
    Mar 2003
    NJ
    911
    Try mothers aluminum polish. It's sold in most car parts stores. Rub away!
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
    NEPA
    7,051
    This only works on Yammies. Razor blade,carefully,gets under that oxidation and takes it right off. Leaves you with the color that was originally there. Now it's up to you how nice you want it. Ride it,or start sanding. You can work your way right back to factory if you have that kind of time on your hands!
    Jul 2011
    Lilly PA
    1,480
    There is a few threads on here for plastic renewal. I found that plastics are different from each make and IMO the Yamahas are a happy medium. If you have access to a buffer I would recomend the razorblade trick like 007 said on real bad spots and deep scratches and then wet sand it from there. Check out some of the threads and Mr. Clean is a top notch restoration guy that has great advise if you need a referance. Good luck and take some before and after pics for us.
    Just sit back and chillaxx
    Maine
    463
    Heres a pic of the front fender...It does come off with alot of rubbing but its scratching the top layer off the plastic..How about putting a clear coat over it after its cleaned good?
    Dec 2009
    BFE
    1,202
    Rub it with real fine steal wool like 0000 then just polish it out with mothers aluminum wheel polish. I've done many of Yamaha fenders in just of bad of shape and they will shine like new with just alittle elbow grease.
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Springfield Mo
    3,309
    http://www.3wheelerworld.com/showthr...tore-with-pics
    There are several other threads out there as well.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Gold Hill, OR
    1,295
    On my YT125 the oxidization was so deep and made pits in the plastic, there was no way of sanding it all out smooth. If you were to sand it out the plastic would be very thin lol. I just used a very hot pressure washer/steam cleaner and blasted it til it was at least yellow again. Still looks like crap though.
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
    Snohomish, Wa
    1,028
    no need to clear coat it. Once you get it back to original color just take care of it, it wont fade again if you take care of it.
    85 ATC 250r -Under Construction
    86 TRX250r
    05 KFX400
    02 400EX
    Maine
    463
    Thanks everyone. im going to try mothers aluminum polish and maybe steel wool and fine sandpaper...
    Abrams, Wisconsin
    739
    amen, one of the most important things is to not leave it in the sun a lot
    86 250sx - old reliable
    another 82 110
    -gone but not forgotten-
    82? 110 - why did i sell it??
    84 225dx - meh, it was a pile
