Results 1 to 14 of 14
Thread: atc 70 frame
    fannitti is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2011
    new jersey
    165
    atc 70 frame
    so i got a frame cheap. it needs to be straightened and i plan on extending it 3 inches and bracking it with a pipe inside all nice. my question is whats the biggest side motor i can do that dose not have a clutch i kinda dont wanna like the semi auto, or amd i gonna have to suck it up and shift? i wanna do a 140 yx motor or whatever there called all done up from tboltusa.com. can i still do a pull start convertion on that? and doing a bigger motor will i need to lift the gas tank for a bigger carb to fit?
    OHIO
    2,857
    Not sure what is the biggest cc semi auto....125 If I recall? You can use pullstart conversion on the china motors.....kits are available. You may need to get creative with a rubber mallet and or raise the rear mount of the tank a bit depending on the carb and intake you run. Intake can be shortened and rewelded or you can just adjust the tank with a rubber ...won't take much but ya it's tight. Hang on when your done....... Plenty of threads on here from Mad70 gang ,Kasey and others. Mosh just built one here lately.....check his build out. Good luck.
    iron river ,MI
    74
    had to ask this? but do alot of honda atc 70 frames bend in the middle under the tank?
    Oct 2011
    new jersey
    165
    yea under the tank
    iron river ,MI
    74
    ok because im fixing up my kid 70 in the basemint, and a friend told me on facebook that it was, and what is that best way to bend it back the right way?
    Oct 2011
    new jersey
    165
    there is threds all over the place on this
    Jan 2011
    Brazil, Indiana
    2,087
    Lifan makes a 140 semi auto motor.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Oct 2011
    new jersey
    165
    really where can you get a lifan semi auto i want one
    Jan 2011
    Brazil, Indiana
    2,087
    I stand corrected. I was thinking of the 125cc. Sorry
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Oct 2011
    new jersey
    165
    ok i was gonna say lol ive been looking all over
    Jan 2011
    Brazil, Indiana
    2,087
    Quote Originally Posted by fannitti View Post
    I was looking at so many when I bought my lifan. I was considering the 125 auto, but I didnt want 3 different trikes with 3 different shift patterns. I settled in the 140 1 down 3 up.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Cincinnati, OH
    3,289
    Quote Originally Posted by u.p ted View Post
    That guy is a great guy! Easiest way to bend it back is if your taking the motor out place a 4x4 where the engine sits. Place a bottle jack there and use another 4x4 across the forks and jack away. Just remember your going to have to go past it a little because the steel has some springs to it.
    "MR.Clean"
    Oct 2011
    new jersey
    165
    ok awsome thanks
    Apr 2008
    Metro Detroit-MICH
    244
    Quote Originally Posted by hoosierlogger View Post
    Yeah.... That's pretty annoying. Still so new to riding so I have to think about it from bike to bike. Thank god the two favorites are semi auto upshifts.
    Alex Stoli
    1986 Honda 250SX-X
    1985 Honda 200X
    1984 Honda ATC 70 w/ piranha 90
    1983 Honda ATC 70 w/ Pitster Pro E110
    TRIKEFEST 2011 vet
    SandPupi's 2011 vet
    Member #13036
