Results 1 to 13 of 13
Thread: 85 250R Caliper rebuild... HELP!
    Oct 2006
    Wickliffe, KY
    125
    I need some advice on what to do about the caliper pistons on my 85 250R. I’ve got 3 calipers and all have what I would consider bad pistons. They all have pitting to some extent and my concern is they will leak. My question is, what should I do? I’ve looked up the parts and they are not available. I looked up TRX caliper pistons and it appears only one of them is available. I’ve searched the forum for hours and all I can find is someone once said that a CR caliper piston was the same size. Can anyone confirm this and know what model or year may interchange? Now I know I can’t be the first person to run across this problem… so what did you guys do? Any and all help is greatly appreciated!
    Oct 2006
    Wickliffe, KY
    125
    Maybe nonody's running rear brakes??? I never had them on my 185s...
    Oct 2006
    Wickliffe, KY
    125
    OK.... I've been researching this issue a lot. It seems I can't find any other Honda caliper piston that will intercahnge. I've read somewhere that a CR plastic type would work but my research tells me they are 27mm in diameter and the ATC250R is a 25mm. I thinking about getting a CR set and having them turned down. Anyone done it or know if it can be done? What's my "other" option for a rear caliper? Can the 85 swinger/carrier accept the 450R bracket and caliper?
    Cincinnati, OH
    3,289
    Look into converting your 250r brakes to 450r!
    "MR.Clean"
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Aug 2010
    Southern Oregon Coast
    932
    I talked to a machinist once about having new pistons machined, but they weren't too hot on the idea. The reasoning was that that have such a tight tolerance, he wasn't sure he could make it exactly perfect. I kind of felt like I was being fed BS, whether it was a lot or a little....
    Jul 2011
    Colorado
    141
    falloutboy,
    If your machinist is worried about tight tolerances you need to find a new machinist.
    Oct 2006
    Wickliffe, KY
    125
    Thanks for the link. I have 3 calipers with bad pistons and I hate to trash them. I'm going to check with my machinest and post up what he says about making the caliper pistons.
    Oct 2006
    Wickliffe, KY
    125
    Just to let anyone searching the forums know, I ended up having my machinest make me new caliper pistons from stainless bar stock. He told me he turned them .001" smaller than original due to the properties of stainless. They have been installed and working perfectly for 2 months now and I'm glad I didn't have to convert my 85 set up. Anybody needing caliper pistions for a 3rd gen 250R, shoot me a PM and I'll see about getting you some made.
    Sep 2007
    100mi west of Chicago
    3,582
    That's cool, thanks for sharing. I junked an 85 R caliper in the past because the pistons were seized and a rebuild kit failed
    Rob
    Cincinnati, OH
    3,289
    Quote Originally Posted by xman2rman View Post
    Whats the cost on these?
    "MR.Clean"
    If he only took off a few thousandths, then he cuts it and faces it, and a couple angles so they slide in. It should be a big deal.....
    I can't imagine them putting the hollow hole in there, so I doubt it's necessary and just a weight thing.
    As long as last cut is super smooth, your golden...........
    Oct 2006
    Wickliffe, KY
    125
    I'll have to get a price, they were done FREE for me. He turned them from 1" SS bar stock. The original dia. is .9775 and he made mine .9765. They are hollowed out just like the original, less surface area to transfer brake pad heat to the caliper. You do have to use a block off plate because they don't have the E brake rod out the back. I'll talk to him this weekend and see if he's interested in making some more and how much they will be.
