Thread: ok need some help with my 200x engine
    200xman123 is offline Quote: "sorry im not the sharpest tool in the shed" Arm chair racerFirst time rider
    hartford vt
    171
    ok so bought a 12:1 piston because my other stock one smoked but ran great. so i get it all buttened up and every two or so kicks it acts like it wants to starts but sputters out . i brang it in my garage and pulled my cdi thinking it was 180 off but it wasnt it was fine :/ i did realize i forgot to gap my pulser coil plate and it was really far apart so i gapped it to .12 like the manual sais and i havnt had a chance to try to crank it again . i think i got my cam timing right , this is what i did i put the piston at tdc while assembling it then put my cam in with the little punch hole straight up with the little key hole for the pulser coil at about 11 o clock did i do this right please help thank you.
    Jan 2011
    Avon, Minnesota
    641
    the black box on the plate has a line on it going up and down. if that is lined up with the line on the pulser when its at tdc it is timed correctly. make sure your are running race gas.
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    hartford vt
    171
    ok thank you and im runnng gas from the airport my buddie races sleds so i buy it off him he gets it at the airport
    Sep 2007
    100mi west of Chicago
    3,582
    You're in luck, I made a thread with pics over the weekend
    http://www.3wheelerworld.com/showthr...tors-with-pics
    Rob
    hartford vt
    171
    thank you very much !
