Results 1 to 8 of 8
Thread: Big Three Wheeler Fan
    Mar 2012
    San Antonio, Texas
    11
    Hello guys, my name is Paul and I have been riding three wheeler off and on since I was about 7 or 8. I live in San Antonio Texas. The last three wheeler I rode was a Honda 200ES but it finally broke. But about a year ago, I traded a bunch of my junk for a running 1984 Honda 200s. After fixing the pull starter and tires, I had a blast on it until I overheated it and burned up the stator coil. Also, the bearings were shot, timing chain was ticking a hair, tail light didn't work, etc. Ever since then, it sat in my shop broken until a couple of months ago when I decided to fix it.
    I went a little crazy on how much I bought for it, but I know it will be worth it in the end. I ended up ordering:
    Pull start rebuild kit
    Armorcord pull starter cord (9000lb tensile strength)
    EBC Clutch plates
    High performance clutch springs
    EBC front and rear brake shoes
    Motion Pro brake cables
    New brake lever for right side
    Front and rear axle bearings from allballs and also the axle seals
    brake drum gasket and seal
    chain and sprocket set
    shifter shaft oil seal
    ignition stator
    CDI box
    coil, spark plug wire, and spark plug
    another used ignition switch that was in good condition
    front and rear brake cam seals and felts
    all new brake springs for the rear (every single spring)
    DG exhaust system
    UNI air filter
    Carburetor rebuild kit
    Fuel petcock valve and filter
    gas cap gasket
    oil drain cap (I broke mine)
    Full engine gasket set
    Headlight and taillight bulbs
    Fork oil seals
    Tubes with offset metal stems for rear tires
    new tailight housing
    rear fender supports (one was missing)
    Everything in the list is installed except I am waiting for the tubes and the armorcord to come in. It runs like a champ except for a little throttle response issue off of idle that I think I know what is wrong. Other than that, it is a blast to ride and will pull wheelies like a champ. One day though, I want to get me a 200X.
    Also, I wanted to tell yall that this forum is awsome!
    Columbia
    5,131
    Welcome aboard! Wow, that's quit a list of improvements! Get some pictures posted of the ride.
    Monroe MI
    5,787
    Jul 2011
    PA, USA
    67
    Can't wait to see pictures, welcome!
    Mar 2012
    Texas
    104
    b o r i n g....
    haha jk he is my younger brother.
    Still going to suck compared to the 200x haha! Im in over 1k now :O
    Nov 2011
    Canada
    221
    Hey you gotta pay to get your way haha.
    Mar 2012
    Texas
    104
    Paul you forgot to tell them about your badass tires!
    STL
    3,560
    welcome! sounds like you really improved that machine! and I would recomend you step into something bigger than a 200x if your looking to go 'bigger' cough*350x*cough
