Thread: how do i change a rocker arm?
    Mar 2011
    oswego county ny
    111
    hi i was wondering how to get the rocker arm out of my ytm200 i have the cam out and the valve covers off but how do i remove the rocker arm? ;/
    You have to get the shaft out. There is always a way to get it out, just take a better look......
    If the shaft is beat up, then you'll need rockers and shafts. (journals)
    Make sure you are at TDC on the compression cycle so the rockers are loose a bit.
    Mar 2011
    oswego county ny
    111
    its like a bolt with no end on it the cam is out the rockers are free
    Nov 2007
    ulysses pa
    1,231
    i think you have to thread a long bolt into the end of the rocker shaft. yamaha had a tool for it i think but i have used a bolt before.
    Monroe MI
    5,787
    Page 79-82.
    http://72.52.143.80/~trikes/ytm200&2...mer_manual.pdf
    If you put the rocker arm shafts in the freezer for a while, before reassembly, they go in easier.
    Mar 2011
    oswego county ny
    111
    how do i use a bolt i found one that fit
