Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: Someone shoot my idea down please!
    We have turboed a 350x pulling bike with a draw thru system . you will need a plenum cause the turbo will probley push more air then the motor will use and it will need to be a SMALL turbo to there are some on ebay . We never really got the bugs worked out of the we built it would build 15psi of boost but would never keep the turbo spooled when it was hooked to the sled . We are planning on putting EFI on it so we can do a blow thru system and be able to change A/F ratios easyer. I don't have any pics on the cumputer here at work but I might have some at home I will look. AND for it to be a rider it will take up alot of room to put it all in there and still be rideable
    Mar 2012
    Texas
    104
    Sent my cylinder off to G&H, they called me today and said that it was already the 4th size over but it could still be bored to the 5th size and remain a 9:1 comp ratio piston so im sending them 155 today to get the work done. I really really really need to find a place to put my new connecting rod on my crankshaft!
    Dec 2011
    Ontario, Canada
    509
    His name is qdude and here is a link to his thread on the build http://www.3wheelerworld.com/showthr...ght=qdude+200x, I am subscribing to this thread and hope you do it because I will be the first one after you to do it with a little guidance from you of course lol then maybe my +6 swinger will come in handy
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    2002 blaster sorry lol
    Mar 2012
    Texas
    104
    Quote Originally Posted by JJMF1979 View Post
    That is a sweet 200x you linked... but can he do my connecting rod or?
    Dec 2010
    S.E. Illinois
    1,178
    ok i'm a little out of my area here, but to lower the comp. why not run one of those spacers on the motor to get the volume you need to lower the comp?
    74 HONDA ATC 70
    Mar 2012
    Texas
    104
    Haha never even crossed my mind! Will take into consideration
    Dec 2011
    Ontario, Canada
    509
    Quote Originally Posted by Rebel Customs View Post
    I would get in touch with him if I was you and maybe you can get this done
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    Mar 2012
    Texas
    104
    Found a place called crankshaft works that specializes in building these cranks.
    Oct 2011
    Glamy's place
    98
    This should be a lot of help with this build. Cant wait to see how this works out!
    http://www.turbokart.com/turbo_exciter.htm
    11
    sure do it. but just make sure its safe, couple ways would be to switch your swingarm out for an extended. or u can install a drag bar in the back in case your front wheels wants to toss u back. to think that atcs can do that without the extra power so..
    Oct 2011
    Glamy's place
    98
    Quote Originally Posted by big specht View Post
    What turbo were you using? Even the turbos that are made for 4cyl cars are way to big.
