Results 1 to 7 of 7
Thread: 85 tri z trans oil in crank help
    Apr 2012
    chowchilla
    4
    I got a 85 tri z for sum reason its dumping lots of oil in the crank shaft and into the header so it smokes alot. I recently replace the crank shaft seals on it still does the same thing im out of options need someone else advise what should i do and a estimate on how much it will cost in a repair shop thanks
    Cincinnati, OH
    3,289
    Do a leak down test and make sure the crank seals are holding. Also might be the center cases leaking. There isnt a center case gasket on a triz but it still might be leaking. A leak down test will tell you where the leak is tho
    "MR.Clean"
    Apr 2012
    chowchilla
    4
    Thanks thats very helpfull but how do i do a leak down test
    Apr 2012
    chowchilla
    4
    Thanks thats very helpfull but how you do a leak down test
    Cincinnati, OH
    3,289
    "MR.Clean"
    Apr 2012
    chowchilla
    4
    thanks how much would it cost me for something like that at a shop
    Cincinnati, OH
    3,289
    call around and ask what they would charge
    "MR.Clean"
