Ok im desesperated right now about jetting.
The z: 1985 tri-z bored to second oversize .5(i think) , wrench report phase 2 , dg exhaust , 38mm miku tm (flat) open lid on air box, v-force reed cage. All bearing , Seal Gasket are new. COmpression 180 psi
Carb: setting right now are : 560 main ,q-2 needle jet , 50 slow, cant remember the needle but its the one that was comming with the carb.
Problem: even at 560 after a plug test at 5 gear wot then clutch+ kill switch spark plug are white + he spitting prestone a good shot. while im riding it he seem to cut a bit on every gear like if he miss gaz.(white plug confirm) but from 450 to 560 its the same deal happen.
So some peaple told me that he could pull some air within seal or somewhere else so I used break cleaner all over the head, reed cage , base of the cylinder and the sound didnt changed. I only have the seal behind the stator to look but hes new.
I had some Issue with my guy who made me the mod to port and head shaving. it ended that i had to put a thicker base cylinder gasket so it raised my port approx. by 0.008 '' My squish test:0.033'' compression 180psi
some told me that its look like you needle jet is too small so even bigger the main jet im stuck by the needle jet that why bigger jet do nothing
that or my port job is ''pass over'' (not sure how to say this but port too big and its bad ) But when i test the Z seem to pull right.
So i hope some1 here will have a good idea to help me there. and if i have to change the needle jet with what i have to switch a q-3 q-5 or switch to a bigger size in letter? like r-2 ?
p.s he dont smell prestone burned and i swapped my oil she had no pretone in it too but she was already dark... but since i rebuilded the bike its the first oil i putted in maybe its normal,.
