Results 1 to 15 of 27
Thread: My 85 250R build thread
    861
    Prob gonna be slow but anyway Heres the machine The pic with the fenders on upside down is now the others are from last year and earlier when it ran. Its a pretty nice machine. All OEM plastic on it. The guy that had it bought it new in 85 and ice raced it til 97 since then it sat in the basement of his condo. I bought it 2 years ago and sized the motor. When I pulled apart the motor I'm glad it did size because of the rest of the questionable things in the motor. Got a new regulator,cdi and coil from BDT today. The chassis bearings are all pretty good on here so I'm gonna powder coat it all original colors, get some new rear tires and keep the stock front,use all the gold wheels and renthal bars. PSI racing hi rev pipe. When I have the money gonna have BDT rebuild the entire motor and put on a 38mm A/S carb. Prob a stainless bolt kit too.
    Attached Thumbnails Attached Thumbnails 2012-04-15_16-42-58_948.jpg   2012-04-28_11-34-50_809.jpg   DSCF4469.jpg   DSCF4466.jpg   DSCF4468.jpg   DSCF4186.jpg
    ]1986 ATC 330R
    861
    Got my 85 all tore down atleast the red and black parts to powdercoat. Should be pc'ed next week. Sent the motor to BDT to have it completely rebuilt.
    Attached Thumbnails Attached Thumbnails 2012-05-06_16-01-34_552.jpg   2012-05-07_19-02-48_771.jpg   2012-05-09_06-55-05_156.jpg   2012-05-10_19-55-26_734.jpg   2012-05-10_20-21-08_817.jpg
    ]1986 ATC 330R
    Ventura county, CA
    30
    Sweet. Know how big a pain in the the build is, but it's worth it to do right. Good luck!
    I am here to have fun, help others, and make some good friends. If you're gonna be a douchebag, don't waste my time.
    Currently bikes: 85 Honda 250R, trx450r, zilla (just sold), lt 250r, blaster, z400, and the kids bikes (Freakin DMV loves me)
    down the road: 2- 86 250r's, 3- 200x's !
    861
    Im gonna trail ride this machine and theres water and mud here so I need the box. I have a 330 esr on my other 250r and a 38mm a/s with the full air box its tight but not bad for working on it. Bad dog toys motorsports http://www.bdtmotorsports.com/ and PSI used to be about 30 minutes from me here in Wisconsin and now is in Utah I think they are in to snowmobiles for the most part. They made 250R stuff in the 80's. http://www.psicarbs.com/snow/sledBigAir.php
    ]1986 ATC 330R
    861
    Got my brake parts, different rads, levers,swing arm,hubs and lower fork tubes painted today. Also I ended up getting a new pivot bolt and bearings,clutch lever and cable off ebay. Monday my motor is being shipped from BDT, all new bottom end,clutch,89 upgrade,crank,billet exhaust flange,39mm pwk for my 330 and put on the 38mm on this build,new v force reeds,stator,cable and red hose kit. Got the frame back a couple weeks ago from PC stainless bolt kit.
    $2400 for bdt motor,carb hoses
    $250 bdt cdi,coil,ac regulator and harness
    $200 for Powder coat
    $125 bolt kit
    $150 clutch lever,pivot bolt and bearings, clutch cable from hellbound racing
    $1500 for original machine in april of 2010.
    The odd and end things Ive gotton for it over time it needed prob $300 and still needs the calipers rebuilt.
    Attached Thumbnails Attached Thumbnails 2012-06-16_14-57-54_973.jpg   2012-06-16_14-58-15_508.jpg   2012-06-16_14-58-24_417.jpg   2012-06-16_15-36-16_991(3).jpg
    ]1986 ATC 330R
    NEPA
    7,051
    Damn nice buddy.. tractor biz must be treatin you good!! Seriously,,your builds are top notch,,tractors and bikes. Thanx for sharing! Will be watching!
    Marty is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2007
    Mesa, Az
    644
    You will not be disappointed with the skills from Carlos at BDT Motorsports. He is very knowledgeable and has many years of experience with those motors and knows how to build reliable horsepower with those 250r's.
    Cincinnati, OH
    3,289
    Where is the psi pipe?
    "MR.Clean"
    861
    Sitting here not in the pic. I had bdt build me a 330total last nov did a nice job.
    ]1986 ATC 330R
    Cincinnati, OH
    3,289
    Put some pics up of it, I wanna see it. Never seen one before.
    "MR.Clean"
    110 atc's Avatar
    110 atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    green bay
    238
    Why the gold on the fork tubes? My tubes looked like crap and I just polished them out to a mirror finish. It's a little more work but worth it. I also have a old PSI pipe but don't use it because it is so damn loud.
    1982 110, 1982 Big Red, 1983 70 Christmas Special X2, 1983 185s, 1984 200s, 1984 200m, 1986 250r, 1987 125m, 1987 lt500r x2, 2003 Rincon, 2008 700xx, 2016 pioneer 1000-5
    861
    All I got for pics of the pipe Ill take more laiter. I thought I'd try gold on the fork tubes. IMO I think it looks good. They were reall gouged from its past life as a ice racer. So I used body filler to fix them up and shot them with Base/clear gold I mixed at work. I use the prophet gun with out PPG paint mixing bank and took pictures of the swing arm gold to get a very close match.
    Attached Thumbnails Attached Thumbnails DSCF6128.jpg   DSCF4186.jpg   Copy of 103_0013.jpg
    ]1986 ATC 330R
    110 atc's Avatar
    Nov 2007
    green bay
    238
    Is your PSI pipe chromed? It looks cool. Mine is just painted black. I've thought about sending it out for ceramic coating.
    861
    Its plated but pretty rusty down by the front wheel.
    ]1986 ATC 330R
    861
    Got my motor back from BDT.Turned out nice.
    Attached Thumbnails Attached Thumbnails 2012-06-28_17-28-00_322.jpg   2012-06-28_17-28-11_598.jpg
    ]1986 ATC 330R
