Originally Posted by
triZtwin
i am having the same problem with mine, but mine is electrical. anyways make sure your getting enough fuel flow from the tank. those like their fuel flow, mine will not run unless the pidcock is on the RES setting, and thats due to a dirty pidcock. also turn your air screw all the way in and back it out one turn and try that. make sure your CDI is plugged in WELL. mine likes to vibrate loose sometime and causes it to run crazy. also hook up your fuel line to your carb with the bowl of the carb off and make sure fuel is passing through the needle and seat. and if it is, then push the floats up and see if the fuel flow shuts off. if that all seems to be fine, you should be good. those things are really simple, but mine sure is finicky sometimes. good luck. o one more thing the the main jet is the big one in the center, make sure that the thing is tightens to is in correctly!! its a grooved slot and when you look inside the carb, "as if you were to look through it from the air box to the head", that little brass fitting should stick up about a 1/4". it will only go in one way, good luck. also check needle height, put the circlip in the center position first, and make sure the little keeper is in place under your throttle spring where the throttle cable runs throuh to the slide, if that little horse shoe shaped thing is missing the neddles will float and cause flooding and what not....i know this from experiance lol.
