Results 1 to 12 of 12
Thread: Socket Size? Refresh my memory...
    MN
    3,263
    Have to dig through my box of specialty tools and noticed one socket missing...
    What size socket is the the steering stem cap nut, the one above the lock nut some call it the finish nut, on the Honda ATC's? I think all of them are the same. Was going to pull and regrease my steering stem bearings this weekend, still tight but getting noisy. I have the spanner wrench for the stem lock nut but i can't locate my large socket for the cap nut that has to come off before it.
    Was is 30mm or 32mm?? Dang this old age syndrome!
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Miami,Fla.(305)
    808
    It is 30mm....
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Beaver Falls, PA
    2,666
    You guys must be pros... I use the tip of a giant crescent wrench with a screw driver through the hole for torque
    MN
    3,263
    Thanks! I knew it was one of the two. I don't own many large sockets so i keep them in a separate box and i knew one was missing! I will pick up another 30mm socket before the weekend, only like $8 at the local farm supply store.
    Is that a Metric crescent wrench? HA!
    Alberta, Canada
    215
    Quote Originally Posted by kb0nly View Post
    Yes. But only if you hold it in your left hand..
    MN
    3,263
    LOL!!! Good one.
    82 250r's Avatar
    82 250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    Utah
    278
    steering stem adjusting socket
    Not to get to off topic or hijack your thread, but i having been searching in vain for the steering stem adjusting socket for my 86 250r. it came loose and destroyed by bearings and races. Do you know where to get one?
    Thanks, Marc
    Cincinnati, OH
    3,289
    Cheap set of harbor freight metric impact sockets for the win!
    "MR.Clean"
    Howdy's Avatar
    Celina, Ohio
    10,079
    At one place I worked I was wrenching on a machine and had a guy helping me. I decided to mess with him and so I told him to hand me a metric cresent wrench. He handed the one to me. I noticed the side that had the standard writing on it was up ( cresent wrenches say metric on one side and standard on the other ). I told him that was the wrong one, I needed one that was metric. I kid you not he looked through 4 tool boxes before he found one with the metric was up. Once he found out the joke he was PISSED!!! The guy was so pissed at the time he tried to get me fired.
    Our boss about blew coffee through his nose when the guy told him what happened ( The boss later told me that was a Good one he will use some day ).
    I did learn this one guy didn't have any sence of humor at all.
    Howdy
    MN
    3,263
    LOL.. Thats a good one. We used to pull stuff like that where i worked also. Sometimes it was a right of passage for the new guys, things like get the wire stretcher this ones too short!
    82 250r's Avatar
    Mar 2007
    Utah
    278
    Found one...
    The socket i'm looking for is Honda part # 07916-3710101 or 07916-3710100
    It looks like this: http://www.shroll.net/GoldWing/stemtool/st1.jpg
    This guy sells replacements: http://www.ebay.com/itm/80-2012-Hond...item231c3aae7c
    Hope this helps those working on steering stems.
    Marc
    MN
    3,263
    http://www.ebay.com/itm/250847870733...84.m1497.l2649
    This is what i use. It works great, cheap, easy to use, etc. Yeah its not a socket but i don't like a socket for these anyway, its not like you torque them down you just preload the bearings and do it to feel, at least thats how i do them. So the wrench works great. I was going to have a local shop stamp a 3/8" square hole in the center so i could put a breaker bar on it if needed but i haven't come across one too tight to get by hand with this wrench yet.
