Thread: Honda 110 piston interchange?
    Jun 2012
    CRYSTAL, MINNESOTA
    3
    Question Honda 110 piston interchange?
    I have a 79 and its time for new piston and rings. Is there any difference from 79 to 85 ?
    Also i noticed gas in the oil? Whats the cause of this?
    Thanks
    Mount Juliet
    298
    There should not be a difference, they are both 105cc. As for the gas in the oil, you have gas that is not being burned going around the rings. However, I would take the bore to a machine shop and have it inspected. It may already be bored. On my 110, I had pitting in the cylinder and its at a machine shop now.
    If I can restore this piece of junk, anything is possible.
    My 83 (Well, now 85 thanks to a warped frame) 110 Build Thread http://www.3wheelerworld.com/showthr...3-ATC110-Build
    My 1981 110 Build Thread http://www.3wheelerworld.com/showthr...44#post1179444
    Jun 2012
    CRYSTAL, MINNESOTA
    3
    Thanks for the info. Also what should i be looking for to determine if the valves and valve guides are bad
    6,813
    Piston and rings were different between the 110 years but if you bought a new piston kit it will work for all years , ring thickness is the difference !!!!
    Gas in the oil is telling me your float valve is leaking fuel into the motor , time for a carb rebuild .
    Mount Juliet
    298
    Thanks for pointing out the fuel in oil, didn't think about that.
    Jun 2012
    CRYSTAL, MINNESOTA
    3
    thanks for the help
