Results 1 to 12 of 12
Thread: Tri-z steering stem bearing question?
    Sep 2006
    Northwest Indiana
    1,893
    As Tri-z owners know, the upper tree bearing is made up of the PITA small independent balls. I'm sure there is a tapered bearing race combo that interchanges, but i've never really looked into it. I am starting to round up pieces for an upcoming build, and would finally like to put an end to this setup on at least one Tri-z. Thanks.
    Tucson
    1,652
    You and me both, haven't seen anything yet!
    Rittman, Ohio
    6,276
    All Balls used to have a tapered bearing for it. I've got one in my racer. Dads on .org used to be a dealer. I dont know current status of him or the bearings though.
    Monroe MI
    5,787
    all Balls... and when you install it the top race will stick up out of the neck a touch,,,, that's normal
    Sep 2006
    Northwest Indiana
    1,893
    Excellent, and thanks guys for the info. Wonder why Yamaha didn't go this route from the git-go? Bryan, can the new top race be installed a bit deeper to offset the height difference in bearings? or is there a step in the neck that prevents that?
    gansevoort,ny USA
    12
    Quote Originally Posted by tecat-z View Post
    the race bottoms out on a stop so you can't go down any farther
    Mexico
    9,014
    Like Raffa said, the top race sticks out. It is supposed to do that, but it looks wrong until you get the dust cap on it. I found my All Balls on eBay and then because they stuck out of the top thought they were no good. I ended up on the phone with them looking like an idiot. Turns out they work great AND they fit a bunch of different bikes, so they should be available for a long time. FYI: I think most OEM use those stupid balls because they are cheaper than tapered bearings. It’s all about the buck.
    New2Tri-Z's Avatar
    New2Tri-Z is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2012
    Redding, CA
    380
    Hey guys, I am currently removing all the races on my frame for powdercoating. Having a hell of a time getting the upper race and lower tappered race out of the steering stem. I am assuming they both have to come out but are they pressed or something? Also cant seem to get the tappered bearing off of the stem itself atached to the lower tripple. Is there a trick out there for getting all of these apart? Please help!
    Currently Owned
    1986 Yamaha Tri-Z 350???
    1985 Honda ATC 70
    1985 Honda ATC 250R
    2006 Suzuki LTR450
    2005 Suzuki LTZ400
    2005 Polaris Predator 50
    2004 Polaris Predator 90
    2-Honda Trail 90's (need to be brought back)
    Feedback Thread http://www.3wheelerworld.com/showthr...-for-New2Tri-Z
    Mexico
    9,014
    A 10” long piece of ½” round bar with square ends will knock out most races easily, just work your way around them to keep the race coming out straight. If there is no part, or lip of the race exposed you will need to weld a piece of flat-bar into the race and beat it out. Some guys weld all around the race and let it fall out, but I prefer the flat-bar. Less welding, still shrinks the race and if it doesn’t fall out you have something to use a drift on. As far as removing the bearing from the tree stem I believe the proper way is to press out the stem and knock the bearing off with a metal tube. However I always just end up cutting them off with a Dremel. I’m not proud of this and almost always knick the stem, so if you do go that route you do so at your own peril. When it comes time to assemble your parts your freezer and a heat gun will help a lot.
    New2Tri-Z's Avatar
    Aug 2012
    Redding, CA
    380
    So the All Balls kit only replaces the top bearing. What about the lower bearing that is pressed on the stem. Looks like Yamaha still sells it but my question is about the tapered race/seat pressed in the frame at the bottom of the down tube, Im powdercoating the bike so was gonna try to knock it out but cant seem to find a part# or anything about replacing it. Plus it looks like a major pain to get it out. Do I just leave it? Or do I try to get it out and if so where do I get a new one?
    Currently Owned
    1985 Honda ATC 70
    1985 Honda ATC 250R
    2006 Suzuki LTR450
    2005 Suzuki LTZ400
    its both bearings and races and dust seals.... the top BB race comes out easy with a punch from the bottom... the bottom race i slice with a torch.. because it almost impossible to get with a punch/air .
    STEM..
    Take a torch and heat the race on the bearing it will pop off easy ... heating the new one will help installing just ask ...
    this will help remove from stem. http://www.ebay.com/itm/CTA-Tools-80...169d1d&vxp=mtr
