Results 16 to 30 of 62
Thread: Project "Deep Threat"
    Big Mike's Avatar
    Hanson, MA
    1,062
    Needs to go to T'Fest '13 and see what it can do on the dragstrip! Awesome!!!
    Currently Own:
    1985 ATC 250sx
    1986 ATC 350x
    Projects/Parts machines:
    1980 ATC 185S
    Plattsburgh, NY
    2,311
    And so what exactly is it? Or what was it? Or what was it intended for originally??
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Sep 2011
    New Castle, PA
    1,134
    is that an RD350??? I absolutely love those screamers. i have a stock rd350 and a modified rd350 (now near 400cc) sitting in my garage. i want to put one in my 200x one day... it would be a dune machine
    Gone:
    Oct 2006
    2,504
    Quote Originally Posted by Tattool23 View Post
    This is an excellent read on what it is.
    http://www.3wheelerworld.com/content...l-stuff-inside!
    Slidell, LA
    4,738
    Mike, are you going to leave this baby as is or are you going to try and give it a little more ooomph (cylinder boring, piston, reeds, etc)?
    Baltimore, MD
    6,088
    There are some goodies available, but nothing like what once existed. Reeds of course. DG Gold heads. The pipes on these were sort of custom with the frame, but there are people who are presently making custom 2 stroke pipes. Of course porting. Different fuels. The hardtail more than likely dates it pre 81 and maybe earlier. Hi Performance frames, especially the hardtail would fit many a different powerplant. They sort of used one basic frame and just used different engine mounts to fit different engines in the basic frame. There were hollow chromoly rear axles available. There were 185s axles available and the real early frames used 90/110 rear axles. The rear brakes could vary depending on the year of the frame as well. My suspension r5/rd trike frame uses the rd front disc brake as the rear brake. Most didn't have a front brake. I've seen custom solid front ends as well as Hi Performances' own front suspension frame set up as well as Honda atc front ends adopted for use as well. Usually takes atc90 based rear fenders and mounts, but often used a fiberglass aftermarket rear fender. Have seen atc90 fiberglass copy rear fenders and aftermarket "wide" rear fenders as well as homemade fiberglass rear fenders. Paint jobs were wide open and ran the gamut from plain to downright show worthy. These frames were the early hot rods of the sand.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Slidell, LA
    4,738
    I did a little searching and found a few websites that sell performance kits for the RD400....bwahahahahaha
    http://www.economycycle.com/servlet/...0-Stage/Detail
    http://www.wilsonperformance.net/Services.htm
    http://www.spec2.com/rd.html
    Cave Rider's Avatar
    Cave Rider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Howes Cave NY
    320
    I have a brand new set of pro wedge 501 tires still with ohtsu labels on them if your interested. Up north ive got no use for them. Text me if you are interested, as im not on here much. pat-518 361 1670
    Oct 2006
    2,504
    Quote Originally Posted by Cave Rider View Post
    Thanks!!! I will be in touch!!
    Spent a little time last night doing some work. It is in fact an RD400, and it has reeds. Set it next to a 70 and a 250r for size and height comparison.
ID:	149981Click image for larger version.
ID:	149982Click image for larger version.
ID:	149983Click image for larger version.
ID:	149984Click image for larger version.
ID:	149985Click image for larger version.
ID:	149986Click image for larger version.
ID:	149987Click image for larger version.
ID:	149988Click image for larger version.
    Terryville,CT
    1,616
    that's an awesome little piece of custom 3 wheeler history! looking forward to your end result! drag or dune?
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Big Mike's Avatar
    Hanson, MA
    1,062
    I love that god damn thing, I want one now!!! That would so much fun to put some small slicks on it and do burnouts up and down my dead end street.
    Currently Own:
    1985 ATC 250sx
    1986 ATC 350x
    1980 ATC 185S
    Cincinnati, OH
    3,289
    nice pull start
    "MR.Clean"
    Oct 2006
    2,504
    Check this out on SLO c-list!! Appears to have been built with RD400 frame and not Hi Perf frame.
    http://slo.craigslist.org/mcy/3110584579.html
    Attached Thumbnails Attached Thumbnails 5Z55Ff5J73Lc3J23N2c6u38e488fb06dc13f7.jpg   5N75L25J83nf3I43Hfc6u39d4f46560b114fb.jpg   5O55Kc5Mc3Ed3G93F7c6u2cc016b2cef41286.jpg
    Slidell, LA
    4,738
    Quote Originally Posted by Mr. Clean View Post
    That is pretty awesome. Wonder why they went with such a small kicker as compared to yours? I would think that would suck to start unless its electric and that's just a backup.
  15. #30
    Jun 2009
    Springfield, MO
    144
    Nice score! I've always loved the sound of the RD. My Dad still has his first Tricky Dick's conversion at his shop which is a RD350. It's on my long list of things to restore.
