i am running a stock carb with a 60 and 175 jet wich was recommended by esr. i have been runnin it and it just has no balls. i am new to jetging so any advice or pointers would be appreciatex thanks.
Go Or Blow
Besides having no balls, what it it doing? or not doing? can you give more specifics?
60 IS QUITE BIG FOR A 310,, i don't even have a 60 in my 350...
I'll have to look but I think I'm running a 52 pilot and 175 main on my 310 with a 39mm pwk.
'86 ATC 250R, Build Thread http://www.3wheelerworld.com/showthr...highlight=250r
'86 "Factory Tri racing" Tri-Z http://www.3wheelerworld.com/showthr...b-Top-Tank-ect
Pile of Tecate Parts
My Feedback Thread: http://www.3wheelerworld.com/showthr...edback-for-bkm
ya 60 is big; i dont know how the stock carb is in reagrd to fuel needs on a 310..... I am running a 39pwk on my 310; i settled on a 170 main and a 50 pilot for mine on 93 octane. I am swapping to race gas when my new dome gets here and will bump up to a `175 main and 52 pilot and start from there.
what reeds are you running? exhaust? theres more than jetting to making one of these 310's run great.
Be careful with ESR's jetting recommendations. Seems like they are a little hit and miss on that but I tend to cut em some slack. They recommended a 50 pilot in my PWK A/S for my 350 with their full exhaust, porting and reedblock. As far as breakin it was a too lean for my liking. It might settle on a 50 after breakin for final tune, but I'm thinking more like 52.
I agree though, 60 is probably ridiculously rich for your 310 (which actually starts life as a 295 from what I have learned). BUT, I would rather be steered too rich than too lean. Try a 52, put a new plug in, run it around at a little under 1/4 throttle for several minutes, listening to your engine to tell you if its too loean or rich. After running it around like that, hold that throttle position while simultaneously pulling in the clutch and killing the engine. Pull the plug and report back as to what color the center electrode porcelin is. Any grayish or white color indicates too lean. Paper bag brown is nice and safe.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
it wont hit the powerband it just boggs. it seems like most u guys are running a 52 so i will try one.
Go Or Blow
also does the air fuel screw lean it when turned in or richen it?
Go Or Blow
in=rich
out=lean
