Results 1 to 8 of 8
Thread: 1985 honda 200x Question about this little oil plug in the head?
    Canada,barrie,Ontairo
    229
    Exclamation 1985 honda 200x Question about this little oil plug in the head?
    Hey Im doing full valve job Brand new everything it the head cam rockers etc... all Honda parts.
    I was looking at my 1983 200x Part motor head & noticed there was a Little tiny Plug by the cam bushing and the back of the cam.
    I went to look on the one i drive all the time & the one im doing the valve job + brand new crank atm & i noticed there was no little tiny plug on this 1985 200x.
    Just wondering why this 1985 200x dosen't have this little black plug behide the cam oil line maybe the owner befor me had taken apart and lost cause it dosen't say anything in the manuel about the little Plug.
    Well here some picture of the little plug im talking about maybe some can tell me about this. Thanks
    This is the one Without the little black plug
    This one has the little black plug
    The one on the LEFT has the Plug & The one on the RIGHT dosent have the Plug in it
    Here is the little black plug taken out of the hole & what it looks like
    Monroe MI
    5,787
    Quote Originally Posted by curtis slawson View Post
    ...it dosen't say anything in the manuel about the little Plug.
    Pages 6-6, 6-18.
    http://www.oscarmayer.net/atc/manual...vicemanual.pdf
    229
    Quote Originally Posted by MonroeMike View Post
    Alright thanks alot Mike. My clymer manual dosnt show or tell you anything about this oil plug .
    So im sopost to have this little plug in it what kinda of damage could have this cost overtime cause my bike ran nice with out it lol
    but ill be getting a new one to throw back into it now
    6,811
    With out the plug you will loose the top end on your motor and wont direct the oil flow to the cam were its needed .
    Southern MN
    1,875
    So why did Honda ever put this plug there? Why not eliminate that hole, so there is no risk of losing the plug?
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Miami,Fla.(305)
    808
    It is there because (Honda) drilled it to make/create the rest of the oil passage up around to the cam journal. The entry hole is no longer (after the oil passage is created....... That hole (opening) must remain plugged, dont lose it, or forget it you will be sorry. You will seize the cam/journals/ & other damage -like Shorline10 said.
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    229
    Quote Originally Posted by 3wheelrider View Post
    yea iv been running the bike for 3 years without that plug havent wrecked anything yet but a new one is order for sure
    It.s merely there because oil passages have to tunnel through and meet up with the oil source.
    I guess a taper pin would suffice but then you can't clean out the oil passage.....
