^ IDK, If he didn't have that. I can't see it working at all.
IDK what stem fits what trike unless I just did it. Kinda like the 200X being a bolt on front end however you need to change the steering stops.....
That 1st nut is where you set your forks and bearings free from play. Then you pop on the triples and it may need to be loosened to allow for the left and right turn smooth.
Many/many/many times I find slightly bent forks that once you set that "special" nut, you tighten the triple clamps and things are no longer smooth. Set to loose and they are sloppy.
You may have to dink around with it ; Such as setting it all and getting smooth upper and lower triple clamps.
THEN, you slide in the 90% bent upper fork tubes and you'll find you need to back off that top adjusting nut a hair and continue it until it's smooth and has no play..........
