so lets see owned this thing for over 2 years.. it has been down more than ridden, first it was the axle bearings, then the piston circlip let go and poked through the rings, then the machine shop screwed up, or i didn't have enough oil in the mix (was at 32:1) and it locked up again, got the top end redone once again, and the carb would not tune to save its life, so to the big bin of used parts it went, and a neeeew carb got ordered, while it was apart i did crank seals, and decided since the rollers in the swing arm bearings were now flat, it was time to bite the big one and swap from bearings to polyurethane bushings, which are now waiting for me to pick them up at the machine shop, then its time to assemble everything resolder the throttle cable ferrule, and tune her in.. woo! also slated to be done are rear shock bushings, and rebuild the forks.. then i will have a completely new trike.. woohoo.. lets hope it holds together for the rest of the season lol
