Results 1 to 15 of 21
Thread: unhappy with atc 70 disk brake hub
    May 2011
    eden,ny
    3,481
    I bought one of these front hubs for a "little" project I have going http://www.hondaatc70.com/Pages/FrontDiscBrake.aspx I had them send it unwelded so that it could be custom fit for my application. I was pretty excited about getting this and buttoning up my project.my excitement was short lived when I received it. When I spoke with them before I ordered it the person I spoke with was going on and on about all the machine work that goes ito this hub so I was expecting a quality part. What I recieved was 5 bucks worth of steel tubing with 20min. tops of machine work to bore the ends.which is pretty much what I figured it would be,no big deal. also in the box was a paper thin bicycle rotor that I'm not very pleased with. the real kicker is the wheel hub which is just a piece of 3/8 mild steel plate cut on a torch table (apparently with a dirty tip) the hole in the center is rough enough that it won't even go on the center tube. When I called to order this he said the parts are always on the shelf ready to assemble but when I called to express my displeasure and to return the parts he told me there is no returns on custom parts. Correct me if I am wrong but arent they off the shelf parts and not custom until they are welded? When I brought up the roughness of the wheel hub he told me that they a cut on a state of the art laser table. so my next question was if you have access to a laser why would you use a bicycle rotor and not make a custom rotor? He assured me that they are top quality shimano rotors. my daughters 79.00 walmart bike has shimano parts! but he says that he has never heard of one failing and he does stoppies on his 177cc atc70. I don't trust it myself and will probably have to have a custom rotor made. so all in all I am stuck with this hub that didn't even come with wheel studs. It will work out for my project in the end but at 220 some odd dollars I feel a bit taken.This just my experience with them and I'm sure others have been happy with theirs but I'm not sure I would buy from them again.the packaging was second to none also,it looked like they went digging in the trash for packing materialsClick image for larger version.
Name:	junk hub 003.jpg
ID:	151055Click image for larger version.
Name:	junk hub 002.jpg
ID:	151056Click image for larger version.
Name:	junk hub 004.jpg
ID:	151057Click image for larger version.
Name:	junk hub 005.jpg
ID:	151058Click image for larger version.
Name:	junk hub 001.jpg
    Jun 2009
    Leander TX
    2,217
    I'll pay for shipping if you just want to send it to me to get it out of your sight
    RiJiD-WILL's Avatar
    RiJiD-WILL is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    los angeles
    271
    thanks for posting your experience its nice to know what you're actually getting.
    Oswego NY
    1,935
    Hey benn will that pitbike rotor i sent out for my chassis bolt up to it??
    MIK6 / Mike
    New England Ride 4/13
    Grande Prairie, Alberta, Canada
    96
    That hub is completely unacceptable for being laser cut !!! I can make cleaner cuts freehand with oxy-acetelyne.
    Oswego NY
    1,935
    hmmmm... I wonder if that disk mount would fit my KX80 front hub....
    MIK6 / Mike
    Nov 2004
    Waterloo IL
    2,701
    I guess they are calling it custom order since they didn't weld it? Dunno. That sounds kind of backwards if you ask me. You can clean that hub up with a sanding disc on a grinder, you shouldn't have to do that for $220 though! If they would have cleaned that up first you might not have even mentioned it.
    The cost alone keeps me from ever trying that kit but thanks for sharing. They have some real high dollar stuff there.
    I wouldn't mind trying a front disc on one of my 70s but it would likely all be made by me. Probably adapt a set up from something else.
    Good luck with it.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,246
    all i am going to say.... i think the prices are hold'em and rape'em ... its to bad ,, there are enough people who can't do their own work but can PAY big for it,,,, so you small potatoes guys get it in the end,, and you know which end!
    springville, PA
    6,185
    I'm personally done with them. You can drop several grand in a month and they still manage to forget parts. Good news is a month and a half later finally got everything.
    Talking about the build quality, I got their exhaust and economy muffler and it fits together like tossing a hot dog down a hall way with nothing provided to take up the slop. Best $200 ever spent
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by MIK6 View Post
    MIK6 / Mike
    the bigger one that we are using for you will if I redrill the mounting holes. I will find one that will work. It just miffs me at the crap they send you and then they pretty much say, sorry about your luck but thanks for your money.
    House Springs MO
    5,496
    Sounds like they are using the same business model that Clarke follows. When we as a group finally stop supporting these companies that produce sup-par products maybe they will wake up and step up the quality and customer service or they will be out of business.
    That rotor stopping an ATC 70? No friggin way!
    May 2011
    eden,ny
    3,481
    I guess I'm not allowed to share my disgust with atc70.com over at 3wo. they edited my thread on there and moved it somewhere where it will never be seen. also they sent me a pm asking not to mention atc70.com. Oh well what are ya gonna do apparently they support shady business practices. It took about 1hr of machine work just to get these sub par parts to even fit together and that walmart bicycle rotor went to a more appropriate place.
    Mar 2007
    Texas
    5,045
    sorry you had trouble. yea i liek to use a palce called tboltusa.com. They are much better priced and offer much better custoemr service in my opinion. they may not have al the extra "70" stuff, but they do offer lots of stuff still.
    ________________
    https://www.mikesatvfix.com
    Yeah Ben, they feel free to edit posts whenever they feel like it over there.
    I did some work and got a 81 or 82R front hub made up with a disc. I haven't even looked at it; I have to get back at it.....
