I got a new set of grips today. Since I've never done this before, anyone got any tips or tricks? I guess I need some grip glue.
i personaly never used grip glue in my life. mine always go on so hard. i use some water wet every thing up and PUSH or pull doesnt matter.
1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
1982 honda 200 bigred cobra exhaust
1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
Thx. I'll give it a shot.
There are threads about this all over,pages long! Listen ,do this,and forget them!Remove old grips,install new grips after spraying any paint in them,let the paint dry over night. They will NEVER twist and you WILL have to cut them off next time. End of story. Use air under the grip,if you absolutely can't get it slid on and lined up. that's it!
what do you mean by "use air under the grip" if you cant get it slid on?
1985 KLT 160
1985 YTM 200ERN
1984 YT 60
Reproduced KLT 160, 110 decals for sale
Reproduced YTM200ERN decals for sale
http://www.3wheelerworld.com/album.php?albumid=2655
Feedback thread: http://www.3wheelerworld.com/showthr...uffin+feedback
Paint? Interesting.
'86 ATC 250R, Build Thread http://www.3wheelerworld.com/showthr...highlight=250r
'86 "Factory Tri racing" Tri-Z http://www.3wheelerworld.com/showthr...b-Top-Tank-ect
Pile of Tecate Parts
My Feedback Thread: http://www.3wheelerworld.com/showthr...edback-for-bkm
^^I use that same compressed air trick to take the hide off a whitetail. It saves a lot of cutting when done on all four legs about halfway up.
Rubbing alcohol works great. It makes the grip slickery and dries with no residue. I never use glue. I clean bar and alcohol makes them stick even when everything else is wet and to get them off, I shoot alcohol back under the grip then hit it with air. The grips always slide right off
I just use either spit or window cleaner. They slide right on and never move. Have to cut them off when you do want them off. Put them on, get them how you want and then leave them alone for a while. I usually let mine sit over night. Never had a problem with them twisting or coming off.
I like flyingw's idea of getting them off. Wonder if you can reuse them.
I use hairspray every time works like a champ!!
wd40 works for everything
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
Hairspray is 100% the way to go, no mess, quick and easy
