Results 1 to 12 of 12
Thread: 250es power outlet
    Hampton, Virginia, C.S.A.
    2,664
    250es power outlet
    ok can anyone explain to me what kind of plug this is? is there an adapter for this so i can actully use it..i have never seen a plug like it lol
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    fingerlakesny
    2,834
    YES , HONDA USED TO OFFER IT. NEVER SEEN ANYONE BUY ONE THO... maybe some of the members have one on a shelf... good luck
    2,664
    is it like a cigarette lighter adapter?
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Sarnia, Ontario, Canada
    3,415
    It is a 12 volt connection and would power roughly the same output as a cigarette lighter..
    I too have never seen any 12v accessories that plug into it because it is an uncommon connector..if it's of use to you then cut the leads and wire in a cigarette socket you could buy from any auto supply store.
    Then you could run things like a portable tire air pump.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Monroe MI
    5,787
    Springfield Mo
    3,309
    I took two male, square or rectangle wire connectors and plugged them in. The fit perfect. You can then connect them to a cigarette lighter if you choose. I used mine to hook up an additional light. This mod worked perfect because I didn't have to cut, molest, or change anything on the trike.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    MN
    3,263
    The stock power outlet connects with a couple bullet type connectors up in the headlight. You could remove the two mounting screws and unplug the wires and stash the stock outlet away for future use then get a cigaretter lighter type outlet with a weather cover and mounting bracket on it and mount it in place of the stock outlet reusing the screw holes then crimp on a couple bullet connectors and plug in up in the headlight and your done. I have done this on a few.
    Just keep the current draw low. Remember with the headlights off you only have about 5 amps to work with, with the lights on you will just drain the battery with anything more than an amp draw on that outlet.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    2,664
    do you think id have enough juice to power a speaker tube set up?
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    3,415
    Quote Originally Posted by threewheelin-feelin View Post
    The alternator on the ES has a 200watt output..
    Find out what the wattage requirement of your speaker is and you will have your answer.
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    MN
    3,263
    Ahh yes thats right, brain fart... The 250 has a 200w alternator, so roughly 15amps. I was thinking the 200 which only has a 60-70w stator, i forget the exact number.
    You can't power really big stuff off it, and if your lights are on you diminish your capacity, but its convenient to have. If your lights are on your loosing 30-50w just to run the lights.
    Beaver Falls, PA
    2,666
    I took off my good plug and used a trashed one to wire in a cigarette lighter. I run a million candle power spotlight, no problem...
    2,664
    im going to have to look at the power that the speaker tubes pull...im trying to find a set up that will fit on the front rack
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
