Results 1 to 10 of 10
Thread: 85' 250r headlight wiring
    Afrothunderkat's Avatar
    Afrothunderkat is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2011
    Richmond NH
    336
    Trying to get my headlight hooked up, when i noticed the wires are too short? Here is a picture. Is this home made? or stock? or what. Can I splice some extension to the wires?
    2003 RM 250 ::: 1985 ATC 250R ::: 1986 ATC 250ES
    Past Trikes: 1985 YTM 225DX ::: 1984 200s ::: 1985 YTM200
    Past Bikes: 1987 KX80BW ::: 2002 TT-R 125L ::: 2000 RM 125
    Quote Originally Posted by Tri-ZNate View Post
    Talking about the build quality, I got their exhaust and economy muffler and it fits together like tossing a hot dog down a hall way with nothing provided to take up the slop. Best $200 ever spent
    Jan 2011
    Choctaw, OK
    2,755
    Yep, somebody hacked on it. I hate it when people do that. Splice as required but soldering extensions is preferred.
    Aug 2011
    Richmond NH
    336
    Quote Originally Posted by Flyingw View Post
    What is the white wire used for?
    Do I only need the green and blue considering there are only 2 connection spots on the headlight?
    Jan 2011
    Choctaw, OK
    2,755
    There should be 3 tabs on the headlight. White is low beam, blue is high beam and green is ground.
    Aug 2011
    Richmond NH
    336
    Think I could run with just high beam? Do I really need my ground? Its the wire that can't reach.
    Also, I understand these are fake HIDs, but are they brighter than standard? http://www.ebay.com/itm/Honda-ATC250...ht_1573wt_1163
    Also, Is this a scam? Or is it viable to put on my 250r? http://www.ebay.com/itm/EFX-SLIM-AC-...ht_9484wt_1163
    Cincinnati, OH
    3,289
    Man,you would be better of just getting new uncut harness
    "MR.Clean"
    na
    5,702
    Go to NAPA..Buy a headlight connector for a 91 chevy S-10 and wire it in to your harness using solder. They are 3 prong and fit the OEM bulbs on the R..I have used them a few times. they cost like 6 bucks..
    Proudly NOT a member of
    "Team on the Teat"
    Jan 2011
    Choctaw, OK
    2,755
    Yes you need ground or the lights will not work but you can run either high or low beams. The bulb doesnt care where the power comes from. The connector Mosh mentioned is an H4 connector. Adding wire to the harness isn't a big deal. You can butt splice or solder the wire extensions.
    As for the Xenon lights, better light over stock. I bought a 10 pack of those and put them on both Rs, all three SXs and put them in my wifes SUV. Its a brighter light in the blue range. Cheap way to brighten them up
    Miami,Fla.(305)
    808
    I put a similar bluish bulb on my '85 250R years back. I didnt use the light all that much & it melted the plastic conn. at the white wire soon after (never used high). Eventually it had a bad/faulty connection........ I also put similar bulbs on 2 of my trucks & developed exact same issues. I replaced the conn. with a NEW one & same thing happen in a month or 2. I had to just elimnate/cut off the plastic conn.-(3 seperate wires) & put my own NEW terminals with heatshrink on the ends & never had an issue with the melting or bad conn. again?- I'd be cautious using high. Just my experience.......
    It does look cool even with the light off. lol
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Jan 2011
    Choctaw, OK
    2,755
    The bubs I bought are 60/55 Xenon bulbs. Those should not draw enough amps to heat up those stock connectors to cause them to melt like that.
