Results 1 to 11 of 11
Thread: Problem with a Honda two piece rim
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    I have one tire that is not holding air. After checking it I found out the air was leaking from the O-ring. Or at least where the rims come together. I tried to separate both pieces from the tire but was unsuccessful. I was able to get one piece broken from the bead but the other was not coming off. Some one used tire slime to “fix” the leak and it just nastied up everything inside. The surfaces where the two pieces meet was rusty and nasty. I cleaned the surfaces up real well and down to bare metal. I painted the surfaces to prevent more rust. The O-ring was intact and I did not feel any weakened areas. It was covered it nasty slime and rust but I was able to clean it. I re-installed everything and found a small air leak (unlike the big one from before). I figured I did not tighten the bolts down enough so as I started to apply torque all the air blew out. I though I destroyed the O-ring. I unbolted the rims and pulled the O-ring out. It appeared to be in great shape and a complete circle like it was when I installed it. So, what am I doing what and what could be the problem?
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Miami,Fla.(305)
    808
    The O-ring may have stretched & doesnt fit like it should. Try new ones but if the area is rusty its not going to work. I've made some new seals with rubberized gasket paper & cut out a (flat) ring for each rim to seal the WHOLE mating surface/s of the rim. Its thicker than normal gasket paper too. Trace the rim half ,cut the bolt holes out-(hollow hole punch needed). Any excess paper/gasket showing by the outside can be trimmed with a razor blade (all the way to the rim). Then it wont be visible. Should work better than the O-ring -if done right/neatly.
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Jan 2005
    5,301
    That sounds like a great idea. Iwill dig through my gasket material and see what I can find.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    philgipson's Avatar
    philgipson is offline At The Back Of The Pack Arm chair racerFirst time rider
    southwest texas
    219
    ultrablack sealant works good.just put a bead on the o ring and the grove.
    86 big red
    85 250sx
    85 atc70
    non illigitamus carborundum
    Jan 2005
    5,301
    Really, I never would have that would work with air. If I do nto have any suitable gaskey material I will try that.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Sep 2007
    100mi west of Chicago
    3,582
    Check out this thread, it has an example of what 3wheelrider is describing
    http://www.3wheelerworld.com/showthr...IM!-(why-not-)
    Rob
    Jan 2005
    5,301
    I think I may know where I can get a rather large but old inner tube.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    MN
    3,263
    Chop up an old innertube and make a rubber gasket, thats how i have fixed this problem before!
    Yet again another prime example of why tire slime sucks!!! Until you see it yourself some won't believe the damage it can do.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Jan 2005
    5,301
    I agree, the trail pros were bad enough. Then, this asshat shot slime in them.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Aug 2004
    Ab Canada
    4,368
    use a bit of grease on the o ring if its still in good shape it should seal,,i use a bit of canola oil on the beads to get the rim to get the rim halfs in evenly, and slowly tighten the two halves toghther in steps..or the o ring will squish oyt of the grove,,,might take a few trys.
    1985 Tri-Z-
    Jan 2005
    5,301
    If it was not so damn hard to break the beads, I would not mind trying it more than once.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
