Thread: Can someone help me with some gearing calculations?
    stevensj13's Avatar
    stevensj13 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Willow Springs, North Carolina, United States
    338
    Hey guys. I'm building an XR 80 shifter cart out of an old beat up roller go cart frame and a soon to be unsiezed XR 80 motor . Anyway, It might be the gas fumes or I might just be stupid but I can't for the life of me figure out the gearing. Could someone tell me what my top speed would be in each gear with the following specs?
    1989 Honda XR 80 motor
    Primary reduction: 4.438
    Final reduction: 3.571
    1st gear ratio: 3.083
    2nd gear ratio: 1.882
    3rd gear ratio: 1.400
    4th gear ratio: 1.130
    5th gear ratio: 0.923
    14 tooth front sprocket (on motor)
    60 tooth rear sprocket (on go cart axle)
    13 inch tall tires.
    My baby - 1984 Honda 200X, Clark Desert Tank, Supertrapp exhaust.
    Monroe MI
    5,787
    I have a manual, I'll get it uploaded somewhere, so you can get it.
    stevensj13's Avatar
    Jun 2011
    338
    Quote Originally Posted by MonroeMike View Post
    Thanks! It has the gearing ratios I need in it.
    WI
    70
    I have a spreadsheet that I made for the 1000x that calculates the speed in MPH for each gear at a given engine RPM. Could probably modify it for your application once you get all the info. Its currently a Google doc but I can copy it to Excel later if interested.
Name:	Gixxer Gearing.jpg
    stevensj13's Avatar
    Jun 2011
    338
    Quote Originally Posted by Redlunn View Post
    That would be perfect. What other info do you need? I can get it for you. I've got the primary and final drive ratios, along with all the gear ratios out of the manual posted in my 1st post. I'm running a 14 tooth front sprocket, 60 tooth rear sprocket, and 13 inch tall tires. The stock engine revs to 10k RPM, if that helps. Thanks
    WI
    70
    This is what I came up with based on your numbers. The spreadsheet is attached if you want to try jacking with the sprocket ratios or engine RPM.
Name:	Gearing Calculator.JPG
    Gearing Calculator.xls
    stevensj13's Avatar
    Jun 2011
    338
    Alright thanks! Yeah looks like I'm gonna have to regear, that'll work for now but a 40 someodd tooth sprocket might give me a better ratio. And also thanks for the spreadsheet so I can mess around with it.
