Thread: honda 185s help
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    honda 185s help
    I have a 185s that i put a 200s rear axle in icluding the sprocket. I also put a new chain on the wheeler. I am having trouble with the chain, while I have the rear end jacked up with it running, I can put it into gear and it tries to walk the front sprocket off the shaft on the motor, what can cause this? what can i do to correct it?
    thanks
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    Mar 2011
    Red Lion pa
    1,542
    Not trying to insult you, but are you sure your replaced it with a 200s axle? I had a problem when I put a 200s carrier on a 200e and tried to use a 200e axle. The lengths are different and will cause excessive horizontal play. Here is the link from when I had my problems. post #5 shows the 2 carriers side by side and the length difference. May not be your problem at all but maybe worth a look. http://www.3wheelerworld.com/showthr...get-it-to-stop!
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 black (project)
    86 klt 185 red
    85 klt 160 (Floyd)
    85 klt 110 X2 (projects)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    397
    the 200s that the axle came out of still had the original tires and they have good tread on them, just dry rotted real bad. the axle that came out of the 200s looked brand new where it rides in the bearing carrier.
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    397
    im pretty sure the 200s was all original as it looked like it had never been touched, everything on it was rusted solid......
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    397
    any help on this will be greatly appreciated. I would like to fix the 3 wheeler and be done with it by this weekend.
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
