Results 1 to 10 of 10
Thread: Tri-zinger seized within a week
    Nov 2011
    New york
    115
    As some of you know i blew up my trizinger with a china pw50 topend around a month ago. Well my christmas present was a new 60cc top end rebuild. I had the cylinder bored .25 over , everything was done right it was honed ,chamfered ,the whole nine yards. I put all OEM in it piston,piston rings, piston pin, piston bearing and piston clips. The only thing was i had the 60cc head shaved and it was shaved to much, so i used the china pw50 head. Also i ordered veshrah gaskets which were very thin(even the china pw 50 head was hitting the piston). So what i did was i made a new base gasket out of gasket paper and it seemed to not hit the head. The next day i broke it in, i started it and let it idle for 10 minutes let it cool down fully, started it ran it around half throttle let it cool, then drove it lightly for the hour after that. The only thing i noticed was that topend when it started to wind it would have a dinging/ringing noise from the top end. then today when i was riding it i was going arond 3/4 throttle then it went bwwuuuuuuuuuuuh and shut off, i went to pull the pull rope and it wouldn't budge. The only thing i can think of is that the piston was hitting the head when going full throttle. I havent dissassembled the top end yet but i will let you guys know what it looks like when i do.
    It just sucks rebuilding something and no more than a week later it seizes. Any input would be greatly appreciated.
    Russ
    Quads:
    2004 Ltz-400
    2012 Ltz-400
    Trikes:
    85 ATC 250r
    85 Tecate
    82 Tri-moto 125(The wheelie machine)
    85 ATC 70
    85 ATC 110
    84 Zinger
    Bikes:
    03 Rm 60
    Sleds:
    05 f5 Firecat
    78 Lynx 275
    Mexico
    9,018
    Ouch! Let this be a lesson to all the kids out there that want to open their presents BEFORE Christmas.
    Clearance tolerances are highly underrated, invest in some Play Dough, or solder wire and a couple of extra base gaskets when you do the rebuild.
    Nov 2011
    New york
    115
    So you think that it could of been the piston slapping the head?
    Quads:
    2004 Ltz-400
    2012 Ltz-400
    Trikes:
    85 ATC 250r
    85 Tecate
    85 ATC 70
    85 ATC 110
    84 Zinger
    Bikes:
    03 Rm 60
    Sleds:
    05 f5 Firecat
    78 Lynx 275
    Rittman, Ohio
    6,276
    The Chinese 50cc head that I used had a smaller diameter cutout than the stock 60cc Zinger head. If you needed a thicker gasker to clear the head, it was probably hitting the outer rim of the head. Zinger OEM 60cc heads are cheap and easy to find.
    Vesrah head gaskets suck. The stock gasket is aluminum, and 2 stroke head gaskets should never be cut out of gasket paper. Probably did not cause your problem, but something to keep in mind.
    Nov 2011
    New york
    115
    I made a base gasket out of gasket paper not the head. Thanks for letting me know about the head diameter
    Quads:
    2004 Ltz-400
    2012 Ltz-400
    Trikes:
    85 ATC 250r
    85 Tecate
    85 ATC 70
    85 ATC 110
    84 Zinger
    Bikes:
    03 Rm 60
    Sleds:
    05 f5 Firecat
    78 Lynx 275
    Scootertrash's Avatar
    In the sticks
    4,638
    Was the base gasket you made the same thickness as the original?
    House Springs MO
    5,494
    I would have like to have known what the compression reading was for that engine before it blew. The sound you heard was probably detonation from to much compression and low octane fuel. The dome was probably way off creating a small combustion chamber and the cast piston didn't like it very much. When mixmatch parts are used they need to be machined to match. Just because something physically bolts on doesn't mean its going to work together and without knowing prior clearances we're all pretty much throwing theories out there.
    I did the bore get trashed? If its salvageable I would do a light hone, get a new true 60cc head, and buy the right gaskets and go from there.
    Jul 2012
    Penfield NY
    660
    Go with what bkm said and also have my brother work on it this time with you.
    "See, morbid and creepifying, I got no problem with, long as she does it quiet-like. "
    Trikes:
    1982 Honda ATC250R(in process), 1984 Honda ATC110, 1984 Honda 200s, 1985 Kawasaki KLT160(not running...yet)
    Quads:
    1990 Suzuki LT250S, 2013 Suzuki LT-Z400, 2014 Honda TRX450R SE
    Nov 2011
    New york
    115
    It was getting around 90 psi of compression. I took apart the top end and yes, it was hitting the head. What had happened was the top of the piston on the intake port side was hitting the top of the head, there for angling the piston upwards and dragging the bottom skirt over the exhaust port.
    Quads:
    2004 Ltz-400
    2012 Ltz-400
    Trikes:
    85 ATC 250r
    85 Tecate
    85 ATC 70
    85 ATC 110
    84 Zinger
    Bikes:
    03 Rm 60
    Sleds:
    05 f5 Firecat
    78 Lynx 275
    House Springs MO
    5,494
    Like I said I was grabbing at straws with my theory, but the piston hitting the head will trash an engine every time.
