Bulbs look fine so whats next
use a test light or a multi-meter and start tracing the wires.
78' 90
80' XL500s
85 200x
Follow the wires back. Are they all connected? Do the colors match? If everything is right take a test light and touch the wires when it's running.
Good spots to start, Good luck! I had the same issue with my 3 wheeler.. took me ages then I finally got power up there.
Edit: Oh just because the bulbs look good doesn't mean they are. I went 3 day's trying to figure out why my taillight didn't work.. ends up the bulb that looked brand new was junk. So if you have extra laying around I'd suggest using them. Unless you just bought them new of course.
1985 Tri Z - Next project!
1982 250r - Sold
1983 Auto X - Sold
1984 Auto X - Sold
1985 200M - Sold
1985 YTM 125 - Sold
1985 185 - Sold
1984 185 - Sold
Check out my feedback:
K thanks for the help guys
No problem Corbo, update us if you find anything and we'll gladly answer your questions! Welcome to 3WW by the way =)
1982 250r - Sold
1983 Auto X - Sold
1984 Auto X - Sold
1985 200M - Sold
1985 YTM 125 - Sold
1985 185 - Sold
1984 185 - Sold
http://www.oscarmayer.net/atc/manuals/
http://www.oscarmayer.net/atc/manual...ice_Manual.pdf
pg 16-2 or pdf page 216
the meat of it's on pg 16-7
I have the same issue with my 86 350x lol.
Good questions to ask/answer
Does the tail light work?
If none of the lights work, then maybe it is more than just the bulb, check the voltage regulater output.
If the voltage regulater checks out good, then a switch/wire issue
This is all assuming the bulbs are good, and you have the headlight switched on.
Check all the connections and test the lighting coil....
Could be wires crossed somewhere also..
