Anybody know if you can use a rear caliper from a different make/model on a 06 ltr 450?
Not sure, you might have more luck over at http://ltr450.theatvchannel.com/invision/
Rob
Anything is possible, but I have to ask why? What is wrong with the stock unit?
Joker 90
1981 Yamaha YT125
1986 Yamaha Big Wheel 80
1986 Kawasaki Tecate KXT500
1987 Kawasaki KXT250B2
2005 Yamaha YFZ450
Just checking for a buddy of mine. His original caliper the bolts seized and broke off. I was seeing if someone used something different as an upgrade or a cheaper option.
Not sure of anyother options that fit but I would imagine the Z400 caliper is the same. I have an 06 LTR450 and 05 LTZ400, they look identical to me but not sure. Also try ebay there are thousands on there you can find a used one pretty cheap (around $75) and Moose sells cheap rebuild kits (around $30) if you need to rebuild it.
Currently Owned
1986 Yamaha Tri-Z 350???
1985 Honda ATC 70
1985 Honda ATC 250R
2006 Suzuki LTR450
2005 Suzuki LTZ400
2005 Polaris Predator 50
2004 Polaris Predator 90
2-Honda Trail 90's (need to be brought back)
Feedback Thread http://www.3wheelerworld.com/showthr...-for-New2Tri-Z
bring it to me.
"MR.Clean"
all of the ltr 450 calipers are the same and i believe the 2009+ ltz 400, when started to look like the 450 also had the same rear caliper
Team Blue: 85 Tri-z 250: under the knife
Team Red: 87 Trx250r 01Cr80 15 CBR600RR
Team Yellow: 06 Ltr450 11 Hayabusa
