Unfortunately I am trying to attend college and have to sell a bunch of my stuff to help pay, after alot of thinking I have decided to part this one out.
1. Works Shock
2. DG cool head
3. DG boost bottle
4. DG pipe
5. DG silencer
6. NASA +5 extended axle
7. 34mm flatslide carb
8. Twist throttle
9. Aluminum Rims (set of 3)
10. Engine - .30 over, needs to be gone through, 130 psi (service limit is 128 I believe)
11. Brand New Barnett clutch kit
12. Brand New Hot Rods connecting rod kit
13. full gasket set
14. Brand new .40 over Wiseco piston kit
15. Stock pipe
16. Maier Vented front fender
17. Tank (inside has been coated in Red-Kote)
18. 83-84 parts bottom end
19. 83-84 .20 over cylinder (needs bore)
20. Boyesen Rad Valve ( trx 250r/cr250)
21. Headlight Assembly
22. Headlight guard
23. Frame (all original, light surface rust in spots)
24. Haynes 250R manual
Anything else you need just ask and I may have it.
