Thread: 84 200x swingarm bearings.. need help!!
    Oct 2012
    Finlayson, Minnesota
    1,066
    Ok so I got my bearings yesterday. Put the rear bearings in, and now onto the pivot point bearings (whatever there called) I got one almost flush with the hole and the 2nd one sticks out half way. The one I put a little dent in from using a socket that slipped.. stupid me but it still roles so i don't care haha. Now for the 2nd one I was using a 3lb and put shims over the socket and got it half way. Now to get that flush can I use a socket.. or do sockets mess these things up? Like the shock from hitting it with a could break them?
    Now I don't have a press OR a big enough vice.. is it possible to rig something up with say my jack and maybe setting it under out bobcat bucket? lol.. homemade press or is there a chance it could bend/tweak my swingarm? It would act just like a vice only stronger.
    I'm just looking for some advice on how to get these little suckers inside my swingarm.
    Thanks everyone!
    1985 Tri Z - Next project!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Check out my feedback:
    Slidell, LA
    4,738
    I woudn't have gone with OEM bearings on the front of the swinger. The 3ww parts shop sells the delrin bushings. They are 25.00, one piece and are installed in approximately 5 minutes.
    A socket and BFH is what I have always used in the past to set the pivot bearings in the swinger. It always helped to heat the swinger with a butane torch while chilling the bearings in the freezer (usually overnight). Also use some oil in the housing and they should go in easier.
    Carthage NY 250r rules
    2,355
    I use all thread and washers to install them. X2 on the delrin.When my auto x is ready for new pivot bearings its getting them.
    250r rules
    Oct 2012
    1,066
    I bought all balls bearings for everything. Ok I will just continue at it then with a socket and . I just wanted to make sure I wasn't going to wreck them at all. Thanks guys.
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    London, Ontario, Canada
    1,059
    Use a pc of threaded rod, some washers, that same socket and a little thinking and they will press in or out, one slip with the or socket and you've ruined the bearing. This is on an R but you can get the idea. Threaded rod is cheaper than dirt and the mechanical advantage of the screw is equal to a press.
    Ross..
ID:	162113   Click image for larger version.
ID:	162114   Click image for larger version.
ID:	162115   Click image for larger version.
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    1985 Green Tecate Sold
    My Wife's Ride
    My Kids Ride
