Rebuilding a 78 atc 90, Took off the 2 big axle bolts, removed the drum cover. How do I remove the drum without damaging anything? Do I need some kind of puller or what? Thanks in advance for any help.
Is it stuck? or rusted in there? Put up some pictures
15, rode my first when I was 10. I own 4... I guess they Just talk to me![]()
<<<<<<<<<< Three Wheels For Life >>>>>>>>>>
(NEW) 1985 Yamaha Tri-z 250 My real #1
1985 Honda 250sx my "new" all original garage baby
1985 Honda 200m My first ride
1985 Honda 200x autox
Easiest way is usually to Soak with PB, then take off the chain/chain cover (If yours is still there, most aren't),and reattach the hub on the drum side and tighten it down. Last, whack the center of the hub with a rubberuntil the axle pops out. It's also a good time to do your rear bearings.
If I can restore this piece of junk, anything is possible.
My 83 (Well, now 85 thanks to a warped frame) 110 Build Thread http://www.3wheelerworld.com/showthr...3-ATC110-Build
My 1981 110 Build Thread http://www.3wheelerworld.com/showthr...44#post1179444
"Is it stuck? or rusted in there? Put up some pictures"
Prolly a bit of both. Thing has been sitting for years. Motor is half torn apart on my work bench, carbs and other miscellanius parts are in two boxes under work bench, working on the rest of the tear down now, hoping to get it going by spring for the "kids" to play with. Will post some pics later when I get back to the garage.
if rubber mallet doesnt work use block of wood and decent sized steel. put the back of the frame up against work bench or something so it doesnt move. just do not hit threads with a steel
it will mushroom or ruin threads.
Trust him. Ask me how I know...
Did you remove the O-ring on the axle? Honda put a o-ring on the axle inbetween the nuts and brake drum. Once tightened down the o-ring will slip into the begining of the drum. The o-ring helps keeps water, dust and dirt out of the splines. It will also bind up the drum onto the axle and can make it a real pain to remove the drum unless you remove it first. I have had many people bring machines to me because they couldn't get the drum off. 5 minutes later the o-ring was removed and the drum just slid off. This didn't work on all of them, but a lot of them it did.
Howdy
hes right
ive ran into that littleo-ring before. but only once, it was one of the first things people left off when they worked on bike. you should be able to see it or parts of it by looking between axle and drum. if its not there then the rust it was supposed to keep out is your problem. then your back to beating the tar out of it. just remember to use a piece of wood to save threads.
get angry with it if you have to
Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
