Does it swap rite on? Which motor mounts do I use any other changes need to be done
I'm no expert, but i believe it will swap right in, but you need to rig something up for the rear brakes.
1984 200x
1985 "auto x" 200x. Had a rough life
1982 atc200
1983 atc200e
198? atc?? w/ first gen 250r front end
1982 atc185s
I'm using my 200m motor (same motor as the 200s but with electric start, and the S has more acceleration) in my 200x. I'm using the 200x motor mounts but the 200s should work. I even had a 185s motor in my 200x to begin with. These are all DIRECT bolt ons.
Not sure what he means rig something up with the rear brakes? (assuming your putting a 200s into a 200x frame) You shouldn't have to rig anything. Only thing you'll have to rig(unless you have the 200x header, muffler) is a motor mount.. at least with mine I custom made one.
Good luck with the swap!
1985 Tri Z - Next project!
1982 250r - Sold
1983 Auto X - Sold
1984 Auto X - Sold
1985 200M - Sold
1985 YTM 125 - Sold
1985 185 - Sold
1984 185 - Sold
Check out my feedback:
I did it a couple of years ago,still have the wheeler.the 185 200s motor will bolt right in,with stock mounts.i cant remember but i had to do something with the stator wires.I made a rear brake pedal out of an 250sx pedal had to die grind the center plastic a little to fit on the foot peg and make a linkage but it was farily easy to make.I could take a pic if it helps u but it's buried in my shed.
The brake petal from a 350x bolts right on. On the 200x the petal mounts to the kick start, not an option if there is no kick start like the 200s 200m and 185s.
I'm bringing the 80's back!
85' 200x - 84' 185s - 85' 125m - 83' xr500
