Results 16 to 30 of 40
Thread: Help me verify the year of my 225dx
    Jan 2013
    minnesota
    5,911
    Hello
    that's probably it, why do you want to know that?
    Oct 2012
    Somerset County PA
    720
    to know what?
    Jan 2013
    minnesota
    5,911
    if thats the breather tube
    Oct 2012
    Somerset County PA
    720
    oh because MonroeMike said the code/vin is right at it
    Jan 2013
    minnesota
    5,911
    It will be very easy to see unless it has also been removed. it is on a flat pad 2" long 1/2" wide. It will be facing up on too of the motor not on the side. If it is not there it's suspicious.
    Oct 2012
    Somerset County PA
    720
    ok i know what you mean, should be easy to find ill still take a pic of the frame where it was, just so you can see what i meant,
    Thanks For all your help i really do appreciate it,
    Jan 2013
    minnesota
    5,911
    Hello Colton
    No problem, happy to tell you what's going on after we see the photos. If the vin was stamped on the frame you can wet sand it with 280 or 320 paper, then get some "metal prep acid" from an automotive paint supply shop, Pour some on a paper towel and hold it on the number area for a minute. do this 2 times and the number may appear faintly.
    Oct 2012
    Somerset County PA
    720
    oh i didnt know it was stamped into the frame? i thought it was like a sticker on it with all the info, i am defiantly gonna check it out
    is there anything else i could use instead of that metal prep we will probably be snowed in tomorrow, and wont be able to get to the store
    either way ill get a number
    Jan 2013
    minnesota
    5,911
    hello
    Yes but it doesn't work as well. sulfuric acid = battery acid or muratic or hydrochloric acid = pool acid they are both the same just a different name. if you have powdered pool axcid mix a little with warm water.
    shoot us a photo of the area though
    Jan 2013
    minnesota
    5,911
    hello
    Yes but it doesn't work quite as well. sulfuric acid = battery acid or muratic or hydrochloric acid = pool acid they are both the same just a different name. if you have powdered pool acid mix a little with warm water.
    use gloves or a cotton ball held with pliers. they wont burn you right away but be careful and wash quickly
    Oct 2012
    Somerset County PA
    720
    Ok thanks for the tips I think I have some hydrochloric acid somewhere around here,
    Thanks again for the help and tips
    Colton
    Jan 2013
    minnesota
    5,911
    great if not use a q tip and dip it in a battery.
    Monroe MI
    5,787
    Oct 2012
    Somerset County PA
    720
    Ok so I used the link MonroeMike gave me and it is a 83 the numbers are 29U-000-693 thanks for all your guys help it is nice knowing for sure what year it is
    Thanks again
    Colton
  15. #30
    Oct 2012
    Somerset County PA
    720
    I couldn't find the number on the motor just yesterday I went muddin and there is just dried up dirt everywhere I'm sure it's there somewhere give me a minute and I will post a pic of that sticker thing on the frame
