Hey everyone, I got a couple real nooby questions.. haven't touched a carb in 3 months so i kinda forgot a little bit. Please refresh my memory =)
So first question:
-Just got my wheeler fired up today for the first time sense it was all taken apart. Obviously after everything I did to it, my previous adjustments to the carb are going to be way off. So at first it blew black smoke, figured running real rich so immediately shut if off and turn the air/fuel mixture screw out 2 turns. All was good after that and I was able to ride it. Now first, 2nd gear are fine but when I "give it" in 3rd + gear it bogs down(i'm guessing to much fuel?)
-When the machines in neutral it will idle sorta.. At first it was to slow of an idle so I turned the screw in a bit and it sounded fine but then after 10 seconds it slowed back down again.. i give it some gas and she stays right where it should idle for another 10 seconds and back down again to a slow idle for maybe 30 seconds and then it'll kill.
-carb is leaking.. it appears right at the gasket but the only thing I don't understand is the carb was PERFECT when I left it.. I left it in a cold garage for 3 months until today. So i figure ok maybe the gasket cracked or something(it still looks good) so I grabbed my brand new gasket that i had laying in my room and put that on.. still leaking. Took carb off another time and tightened even more and threw a glue like substance around it just to see and nope it still leaks from that spot. Floats are not sticking and everything inside is brand new. Looks like its coming from the air/fuel mixture screw area but I could be wrong. (gas sits on that screw like water does before it drips)
-Now this last question isn't carb related but I figure I'd ask. So my Run/Off switch does nothing anymore lol.. I have headlight/taillight (don't look bright then again I checked in the daytime haha) but literately the Run and Off does nothing and its kinda scary so does anyone know where I could start to look?
Thanks everyone.
