Results 1 to 11 of 11
Thread: lectron carb
    oile's Avatar
    oile is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2012
    kansas
    600
    lectron carb
    Does anyone run a lectron carb on there trike? I was thinking about buying one but I don't know anyone that owns one to ask if its worth buying one or just stick with my pwk 38 that I already have on my z.
    Oct 2012
    Finlayson, Minnesota
    1,066
    well I have a lectron carb on my banshee.. I looked them up to see what people think about them and I guess a lot don't like them.. on mine there are no jets, i forget how you adjust it though. There also expensive lol
    1985 Tri Z - Next project!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Check out my feedback:
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by oile View Post
    Hello
    A Lectron carb will do nothing for you. The Keihin you have is an xlnt carb.
    Why do you want to switch?
    Does your bike not carburete properly ie flat spots, burbles/sputters etc upon acceleration?
    Do you want more horsepower etc?
    Hope this info helps.
    Oct 2012
    1,066
    Yea I suggest sticking with your keihin. The lectrons i got were like 400 each.. not worth it lol
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    oile's Avatar
    Nov 2012
    kansas
    600
    Just thought I would try something different and maybe run better no real reason
    Jan 2013
    minnesota
    5,911
    It will not run better. If it does not run good what is it doing?
    Take that $400.00 and get your cylinder ported or get a pipe instead, it might run "better" then.
    oile's Avatar
    Nov 2012
    kansas
    600
    My trikes run good I have Sprock heads and intakes dynoport pipes lightened flywheels v force 3 reeds port work done by flotek pwk 38 carbs I was just curious if I could get more out of them. If you know of anything else I can do I would love to here your input.
    Jan 2013
    minnesota
    5,911
    Hello Oile
    Very nice stuff, unfortunately in your particular case as long as they carburete well and you’re cranking compression is at around 180 or more then you can’t really make them “run better” unless you play with the timing a little or replace your stock ignitions with one that has a progressive advance. The only thing you can do to those bikes is make them run “different” like doing more porting, installing Boysen “ports” modifying intake side of piston, chrome plating cylinder liner or using a pipe with a different rpm band bigger carb if cylinder will flow enough for one etc.
    If your cranking compression is less than 180 psi you can increase it to at least 180 psi and run race fuel.
    The last person that asked me this had his bike maxed out and still wanted more “power”. I told him if he wanted more power he needed more displacement with all the same mods.
    STL
    3,560
    nice response Barnett! There are other small things you can do to push your current mods like stated above, I switched over to a higher compression dome so I could run race gas and make a little more power on my 310.
    On the Lectron subject, not that its a viable path for your bike is it sits, but CraigB is running one on his Sphynx 370 250r based motor with drag pipe. He is running pump gas I believe and the Lectron runs all around fine for him. Gary Crum was running a Lectron on pump gas if I recall Correctly too on his polaris 400 2 stroke with inframe dragpipe
    Carthage NY 250r rules
    2,355
    From what my race buddies tell me Lectron carbs are best for drag racing. I think you change the slide needle to jet them up or down.
    250r rules
    STL
    3,560
    YA they are simple to adjust, just pull the slide and screw the needle in or out. Funny to watch someone jet so easily
