A couple tests I would do to make sure you are good to go. First, a compression test to see if the rings are still good. The correct compression is 156psi +/- 14psi.
The next test you need to perform is a two stroke pressure test. Below is a link to how to properly perform a pressure test and you can also purchase the three way valve from Harry Klemm himself. Harry is building mine right now and its a helluva lot cheaper than the motion pro tester. The motion pro tester is below the klemmvintage link.
http://klemmvintage.com/airleaks.htm
http://www.ebay.com/itm/Motion-Pro-2...4a0208&vxp=mtr
