Results 1 to 10 of 10
Thread: A question of engine noise
    Mar 2013
    kansas city
    141
    as i've said in prior posts i have a clicking noise coming from my engine i kinda let my last post fade about this but i've been thinking on this a while
    i put my stethiscope on it and i've found that the clicking sound is loudest from rear valve cover. i can hear chain noise i dont know wether its good or bad chain noise but i can hear it none the less
    i cant seem to post a video of this from my phone but i dont know whats up with that.
    what do you think would definitely fix this noise. and also what should i replace while i've got it opened up?
    EDIT
    Sorry its and 86 250es big red
    Apr 2012
    USA
    4,133
    Does it sound like this video at idle? http://www.youtube.com/watch?v=lpt6CGB89dg
    To me that sounds like the timing chain, you can even hear the slap in that video. My 350x sounds like the top end is knocking, but it is the timing chain on that. I never hurts to check your valve adjustments per the service manual specs, and if it is at least close, it probably would be the timing chain. You could pull the timing chain tensioner bolt out and put a small reg screw driver in it and try to tension it more, but if it is all the way in the chain needs to be replaced.
    EDIT:
    Next YouTube video down has the same sound as my 350x timing chain. It sounds like a tick in the top end, but is really the timing chain slapping around.
    http://www.youtube.com/watch?v=d6QeRQ8QuNw
    Mar 2013
    kansas city
    141
    it soundslike the 350x but not nearly as pronounced and i can definitely hear it louder in the rear valve cover with the stethiscope
    Oct 2012
    Finlayson, Minnesota
    1,066
    Honda 3 wheelers are known are that ticking on the top end.. mine ticks and everyone else i know that has one ticks. Your valves might need to be tightened. Pop that cover off and see how loose it is.. it should barely move, at all. Chain noise.. maybe cam chain is loose? Try tightening that up. Its the screw underneath the black rubber thing on the bottom end right behind the top end. You don't want that chain loose because it could skip a tooth, and well it wouldn't be good.
    1985 Tri Z - Next project!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Check out my feedback:
    Woodsrider's Avatar
    Woodsrider is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    Eastern Passage, NS
    238
    Quote Originally Posted by CodyRosa View Post
    He's got a 250 Big Red , and they have an auto-adjusting cam chain tensioner. They're not like your 200cc and 185cc manual adjust tensioners.
    Slidell, LA
    4,738
    Have you adjusted the timing chain and adjusted the valves? If not, I would try that.
    Mar 2013
    kansas city
    141
    Nope I haven't done anything to it yet ill try it and see. Is the how big of a deal is it to replace the timing chain
    Slidell, LA
    4,738
    Quote Originally Posted by xela456 View Post
    alot easier to adjust the timing chain than it is to replace
    Oct 2012
    1,066
    Ahh thanks woodsrider, did not know that!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    time for a new timing chain
