Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 31 to 45 of 105
Thread: As Promised...The RT250R Build Thread! Reverse Trike 250R THREETRAX
  1. #31
    Kentucky
    511
    I hope the front weight bias won't make it nose dive when you jump it. Can Am does some interesting stuff with the frontend geometry. The a arms aren't parallel with each other like the trx.
  2. #32
    Plattsburgh, NY
    2,311
    Quote Originally Posted by stroberts22 View Post
    I was thinking a bit about that too. I think that this ill be the biggest issue with the machine. I think the sway bar and width and suspension will all come together to make turning/sliding very doable. But the weight front to back could be more of an issue. I do know that the missile swingarm is extremely heavy. It is very big and all steel with the jack shaft 2 chains, the rear hub and so on. My 250R has an aluminum swingarm so really the quad axle and having another tire and rim is the biggest difference.
    I plan on weighing the missile rear end and the trx rear end to c the difference. Hopefully it won't be as big a difference as we think.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
  3. #33
    Plattsburgh, NY
    2,311
    ok so a little progress this weekend. still at some thinking and getting some parts and looking and deciding to c what will be done.
    i weighed the TRX as it was just how i bought it. it weighed in at 372lbs.
    i also set the missile kit rear fender on it with an '86 ATC seat. i just wanted to c how close things are. i will for sure need to use the TRX seat so it fits the gas tank better. the rear profile and size of the seats r the same. so i will be cutting and drilling the missile fender to accept the TRX seat and latch system. i will need to trim the left side of the fender to get around the coolany overflow bottle, or move the bottle up underneath as long as it clears the tire on fully compressed suspension.
    i also got my new front tires and rims for the project. went with Carlisle Trail Wolf's for the fronts because i also have one for the rear. i like the tread and look and think it will be nice to have them all match. upon looking at it i really think the power of the 250R will greatly overwhelm the single rear tire. i was thinking of maybe getting a wider flat profile rear tire like a RAZR 2 with bigger deeper lugs but there really isnt a lot of clearance inside of the missle swingarm since it was designed to fit the ohtsu 250R rear tires. i bought the Trail Wolf rear because it is a slightly rounded/ balloon style. this was with the intention of having it be on an actual ATC 250R to make it a 2 wheeler like the missile kit is intended. so on that application u need to lean the bike like a dirt bike to corner so a rounded tire would be better. i am still building one of those also but thats another day and another thread in the future.
    so i assembled the missile swing arm. i pressed in the pivot bearings and ends and caps and then put on the rear tire and rim, the wave rotor and the 39 tooth sprocket. i also pressed in the wheel studs into the hub of the missile kit. only thing left really is the brake caliper and the 2 chains. then i will weight the complete missle set up so i can compare it to the stock TRX set up. i will tell u that the missile kit set up is seriously heavy. its all steel and very thick at that. i dont think there will be much difference in the two rear ends which is great. but we will c.
    here r a couple pics. i couldnt resist bolting the swingarm up to a current 'R' project. check it out!! as said before one of these will be on the way too.
    but can anyone notice anything about the mocked up 'R' ???? c who can figure it out....
    believe me its off the ground...
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
  4. #34
    House Springs MO
    5,494
    So what engine fits that new cradle in that atc frame?
  5. #35
    Plattsburgh, NY
    2,311
    ^^^^..... y o u r onto something
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
  6. #36
    ONEBAD350X's Avatar
    ONEBAD350X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2008
    Iowa
    339
    nice work! I want that missile swinger!! LOL
    85 350X
    85 330R
    85 250R
    86 250R
    86 200X
    86 200X
    AVATAR IS MY OLD 350X
  7. #37
    Feb 2006
    EC
    1,607
    I think I know.....................
  8. #38
    Feb 2013
    Brazil, Indiana
    728
    Nice to see someone thinking outside of the box LOL. I thought about doing this myself but funding shortages wont allow me to do so and my wife thinks im crazy too! Waiting to see this come together
    1979 ATC110
    1983 ATC110
    1984 ATC110
    1984 ATC125M
    1985 ATC110 2 of them
    1985 ATC110 The wife's
    1987 ATC125M
    1985 ATC250ES
    1984 DX225 with 250 timberwolf engine and swingarm. Wolf in DX clothing
  9. #39
    Springfield Mo
    3,309
    Looking good. I have the magazine with the article covering the reverse trike. I can scan it in if you would like.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
  10. #40
    Woodsrider's Avatar
    Woodsrider is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    Eastern Passage, NS
    238
    Quote Originally Posted by Trike_crazy View Post
    I'd be willing to bet that most of our wives think we're crazy...lol. I can't wait to see the finished product. Too bad you hadn't done this when I was still living in Montréal...
  11. #41
    Plattsburgh, NY
    2,311
    Quote Originally Posted by thestud25 View Post
    yeah is that the one with the astro kit on the big wheel?
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
  12. #42
    House Springs MO
    5,494
    Well, what powerplant is going in the atc frame??????
  13. #43
    Plattsburgh, NY
    2,311
    Any guesses?
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
  14. #44
    Columbia
    5,131
    250x engine?
  15. #45
    Springfield Mo
    3,309
    Quote Originally Posted by Tattool23 View Post
    Hmm good question. I'll look tonight.
    CR500 motor?
    RIP Ninja!
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
