i just bought a 85 200e and i cant get it into reverse can someone help me or give me any tips please?
Yamaha did not make a 200e Honda did. And it still didn't have reverce. Its probably a Honda 200es or a Yamaha 225dr. Does it have hi and low range also or just reverce? And does it act frozen up or just won't move once its in reverce?
Own-Honda 250es, Kawasaki kx60, Yamaha 350 warrior
Owned-one honda 350x three honda 90 s, one honda 110, one honda 185 , three honda 200e s, two honda 200s, one honda 200es, one yamaha 60, four yamaha 125 s, one yamaha 200, one yamaha 225dx , and two kawasaki 160 s, all of wich were good runing three wheelers. Also had lots of parts bikes. Also had lots of dirtbikes, 4 wheelers, gokarts, mopeds, and snowmobiles.
no its a yamaha sorry i just no its a 200 or what ever and it just wont go into reverse when i try and move the shift thing back it wont go in
and it just has reverse
the reverse shifter wont go into reverse
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
ok but why wont the reverse go in?
The yamaha 200 has to be in 1st gear in order for it to go into reverse. Hope that helps!
i tryed that it wont go fully in?
it will go in abit then kick out
Do you mean it starts to move then kicks out, or the shifter goes in and pops out without even having it move? I have seen exactly one 200ERN, not very common around here for some reason probably because we used to have like three Honda dealers back in the day.. LOL
The one i have seen belongs to a guy i did some work for, we used it to haul some wood around on his farm, i always had trouble with reverse on it as well, but it would go into reverse then give it some gas and start to move then pop out, it would usually do that a couple times then stay in, never could figure out why.
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
wont even go in like it will go up so far and u can feel the shifter want to go in reverse but it wont, idk whats wrong with it, could there be a shifting problem with that or is there a special way to put in in reverse?
when i try and put it in and think its in il give it gas and it just revs but if i really pull on it , it will kick half way in reverse abit then kick out
Are you sure you are squeezing the red handle on the lever as you try to put it in reverse? Also there is an adjustment on
the linkage. Just back off the small nuts on both sides of the adjuster and then turn the adjuster accordingly.
