Originally Posted by
Cave Rider
yes he is probably correct in saying it is the counter balancer, the whirring sound comes from the bearing that is surely going to be worn. unfortunately the bearing and the balancer is unavailable. you have three options.. first, you can live with it and it will probably be okay. second, find a used balancer with a good bearing. or last, find someone to press the gear off of the balancer and replace the bearing with one you can find from a bearing manufacturer. if I remember correctly the only bearings I could find were slightly wider. but with a little ingenuity you can make them work. PS, if you go this route make sure that the gear gets pressed back on in the same location it came off. good luck !!!
when i ordered my bearing kit of ebay for my 250r it came with both bearings for the balancer and they fit perfect
current rides
82' ATC110
85' ATC310R
85' ATC250R
85' ATC250ES
16' brute force 750
