Hello, I am new here and I have an ATC 185 engine that is now on a custom go-kart and I had a few questions and problems.
1.) This is a recent problem I have been having, after about 15-20 mins of run time the engine begins to break up and occasionally stalls. Its almost as if there is
an interruption of fuel flow or too much when it stalls for it happens when I put my foot into it. However I do not think its a carb issue or fuel issue, I am thinking it is the stator coil or the CDI, it has a brand new coil and plug so that will not be it. I am willing to bet this is an ignition problem but wanted additional opinions.
2.) It has been about 15 years since I disposed of the frame (due to one hell of a wreck, some things just should not be attempted on smaller bikes) and I do not recall the year of the bike I think it was somewhere in the 82-85 range, is there any way to tell from the engine what year for parts ordering purposes.
3.) It has the automatic clutch on it and when shifting through gears it takes a decent amount of time to fully shift into the next gear when I shift up, but shifts down just fine, does the clutch need adjusted or replaced?
4.) Does anyone know the max bore for the ATC 185 I would like to bore the cylinder but wont touch it until I know what the max I can go is. (Not looking to have no options if SHTF)
