Thread: 81 ATC200 Low Compression
    Apr 2013
    Tampa
    16
    Guys,
    I have rebuilt my engine from ground up. I installed new valve guides, valves, piston, and rings. Had the new valves machined to fit, cylinder wall honed. However, when performing a compression check, I only get 135 psi or so. Therefore, connected a leak-down tester and at 100 psi, I can feel a small amount of air leaking from the crankcase vent. Also, there is a small amount leaking from the top end from the valve adjustment cap hole (removed cap to adjust valves).
    Is a very small amount from the crankcase vent normal, as well as from the valve adjustment cap if off? Just not sure why I would have low compression. I may need to adjust the valves but even with no tension on them, I may have some leakage past the valves. Won't know till I can stop air leaking the other two places.
    I did not bore the cylinder. Only honed and re-installed original spec piston and rings. I may need to install over sized piston and rings.
    Total, with 100 psi, I'm loosing around 20 psi in leakage.
    Also, would this cause a very rich gas mixture situation? My spark plug is black within only a few mins of idling.
    Any advice would be great. Thanks!
    Cornholio's Avatar
    Cornholio is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2012
    Staples Minnesota
    180
    I think, It may be because the rings have not seated properly yet. So the pressure slips by and blows out the crankcase breather. Im probably wrong, but thats my thought.
    Life is short, Party naked!
    1986 250r
    1984 200s
    1984 250r
    1970 us90
    1991 Yamaha Blaster
    1984 110
    1985 110
    1984 200x
    Oct 2012
    Finlayson, Minnesota
    1,066
    You got the same problem I have right now. You have to bore the cylinder not just hone it. Your cylinder is more than likely an egg shape. OR you put the rings in upside down.
    1985 Tri Z - Next project!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Check out my feedback:
    Dave8338's Avatar
    Dave8338 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2013
    Central MN
    378
    ... or have the oil ring over lapped OR have all the ring gaps lined up.
    The Goal... All I Need Is The Time...
