Results 1 to 15 of 23
Thread: picked up this '77 ATC 90 last night...for 40 bucks!!! Some questions too :)
    Dec 2012
    812
    Didn't think I'd ever be able to buy a complete trike for under $100. The ad said $75 obo. I offered him $40 and he took it!
    Seller said he inherited it from his uncle who passed away last year. It's been sitting in storage since. He didn't know if it ran or not, but I figured at the least I could part it out and make my money back. It has new tires with lots of tread left so I figured I couldn't go wrong. Well when I brought it home I checked and it has spark, so I think I'll have no problems getting it going. I'm sure the carb is gonna need a cleaning, air filter replaced, etc., but all in all should be a decent little trike.
    From what I can see so far she'll need new brake levers/cables, seat recovered, and tank cleaned out. I was suprised to see the rear fenders are made of fiberglass - I guess this was what Honda used prior to plastic (?).
    I do have a couple questions though that I noticed right away:
    - The seat just sits on the rear fender unit. I'm going to get it recovered, and just wondered if it's supposed to fasten to the fender somehow. Or does it just sit on there like that?
    - The front brake drum seems to be at an odd angle for mounting the brake cable (see pic). Does anyone know if it should be spun around and secured to the front fork somehow?
    - The exhaust has no muffler...only a straight pipe from the engine. Other than being loud and likely the odd backfire, will it harm the engine/valves to run it this way?
    - The ignition switch is located on top of the front headlight, which seems like an odd place. I did some quick searching, and it looks there's supposed to be a kill switch on the throttle housing as well(?) The throttle I have has no kill switch on it, and it doesn't have a hole where one would go. Maybe some models didn't have this feature?
    - Is there something else I should check or watch for on these trikes? I don't know much about the 90cc's, never owned anything under 200cc.
    Thanks in advance for any help
    *I also include pics of the original warning decals. Thought they were kinda neat...especially the one about the "altitude compensating carb".
    Attached Thumbnails Attached Thumbnails '77 ATC 90 (1).JPG   '77 ATC 90 (4).JPG   '77 ATC 90 (13).JPG   '77 ATC 90 (6).JPG   '77 ATC 90 (7).JPG   '77 ATC 90 (8).JPG
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Mar 2007
    Texas
    5,045
    There should be a seat pan that bolts to the fender. it uses simular squared headed nut things like the early model 185's did. you will just need to unbolt it and should be good.
    BTW, you got a steal of a deal sir!!!! enjoy it!!!
    ________________
    https://www.mikesatvfix.com
    STL
    3,560
    i want a 40$ 90! damn it! price is right, make it shine!
    Worden18's Avatar
    Worden18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2013
    Minnesota, USA
    298
    Nice find! Good luck on getting it running; let us know when you do
    My Trikes:
    1983 Honda 185s
    1986 Honda 250es Big Red
    1985 Yamaha 225 DX
    1984 Yamaha 200EL "Yamahauler"
    Mar 2013
    Central PA
    2,362
    Im surprised he didnt give you your money back for gas to get home with a steal like that.
    North Dakota
    1,643
    Great Find. As for the Brake drum up front. That isn't a factory 90 option. Looks like it could be off a 185 or something similar. For the kill switch on the throttle housing all 90s had that. So that might also be off the same 185 or similar. As for the straight pipe. I have heard that it is not good for the valves do to all of the back firing it will do. And for anything else. These are awesome little machines!! Haha Keep us posted when you get it running!
    Cold Lake, Alberta, Canada
    3,019
    The seat has no pan like you normally see. It consists of a partial pan at the rear with two bolts that protrude through the fender and two metal plates that sit on either side of the seat that also have two bolts. These two plates sit in pockets of the cover and keep the cover down. It's tough to explain. I did up a 78 ATC 90 a few years back and just made a pan out of heavy puck board and bolted it through the fender. I'm in the process of fixing a 1977 ATC 90 right now; they're easy to work on I find.http://www.3wheelerworld.com/showthr...uot-Fugly-quot Yes the fibreglass is factory. I like it because the average joe can repair it with some patience.http://www.3wheelerworld.com/showthr...reglass+repair
    BTW the reflectors and extended rear grab bar are Canadian only options (maybe Europe too?) You stole that thing; I paid three times that much for "Fugly". PM me if you want to discuss issues you come across.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Dec 2012
    812
    Thanks for all the help guys. I see now that the front hub/brake drum and thumb throttle came off another model. I guess they only had rear brakes on these things.
    Coolpool...
    - Could you post up a pic or two of the seat pan on these things. I was trying to visualize your explanation but I'm having a tough time wrapping my head around how the seats supposed to mount to the fender. Looks like I'll have to fabricate something because there's no pan of any kind under the foam on this one.
    - The grab bar on mine looks like it sticks out further than "Fugly". Do you know if mine is stock or has it been modified?
    - Is there anywhere I should be checking for cracks on the frame of these?
    - What's the blue cap on "Fugly" for...you mentioned something about cam chain adjustment hole...Is this something I should be checking on mine?
    I'm sure there'll be more questions as I start going through the trike...like I said this is unchartered territory for me
    Oh and, I know this is a long-shot, but if you have an exhaust for these things you want to sell let me know. I'd be willing to pay a good price for it
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    3,019
    Here you go Big G. There's no pan at all;just the partial at the rear and the two plates that fit in pockets that hang down the sides of the fender. You should have two holes just above the "Altitude Adjusting" sticker and the same on the other side. Hope the pics explain better. The finished seat is a US90 one so the rear pan is a little different, but they have the same type of bolt up. It appears to me that all your hardware might be under that seat already. They rust out fairly easily so who knows? Your rear grab bar is the same except someone welded on a trailer hitch or flag mount. If the frame isn't rusted out it's probably good. I don't know of any weak spots that routinely crack, except maybe around the grab bar mounts. The blue plug is not supposed to be there. The PO lost the cam chain adjustment cap and stuck that in instead. Sorry, no spare exhausts.
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    MN
    3,263
    These frames always crack at the seat/fender release lever, right in the middle of the frame. If you got damage thats where it will be i guarantee it. The 90, 110, and 125M, all suffer from that problem. Jump it hard a few times and it cracks through the weakest point in the middle due to those long oval holes the seat/fender release rod moves in.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Dec 2012
    812
    Thanks CP...that helps alot! I took a closer look at mine, and you're right, the remnants of the partial pan at the rear are there. I would have never recoginzed it though as it's rusted pretty bad. Looks like I'll be manufacturing something to hold the seat down once I get it reupholstered. As for the exhaust I'll just weld on a muffler off another 70cc - 110cc dirtbike/ATV. I found a stock one on eBay, but it will cost me $130. Also, do you know if these trikes were manufactured with only a rear brake?
    Thanks again for posting the pics and all your help!
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Dec 2012
    812
    Quote Originally Posted by kb0nly View Post
    Thanks kb0nly...I checked mine and she's still solid!
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    North Dakota
    1,643
    Yes these old guys only came from factory with only rear brakes...
    MN
    3,263
    I have always thought about adapting some front brakes to one though for better stopping power. What do you think that brake and wheel on his is off of? I wonder did they swap the forks as well because otherwise there wouldn't be anything for the brake assembly to key into so it didn't rotate.
    EDIT....
    I took another look at his pictures. Thats a 125M front wheel/hub/brake assembly. The notch where the pin of the forks is supposed to go is ahead of the forks and not sitting right. Obviously it must have the wrong forks or they installed it wrong.
    Is there a metal pin sticking out on the inside of the fork on that side? That should be in the notch of the brake assembly.
    North Dakota
    1,643
    I'm not certain but I'm going to say 185s front brake drum it looks like. I'm wonder if they didnt wedge it or just let it sit on it? Idk lol nits interesting! Haha
