Results 1 to 13 of 13
Thread: 200M Decomp lever/camshaft seals
    Oct 2012
    Finlayson, Minnesota
    1,066
    Hey guys, I need help finding these 2 seals.. I pulled them but there so worn I can even read whats on them lol. The decomp lever seal looks like 12 20 6? Why are these seals so difficult to find lol
    1985 Tri Z - Next project!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Check out my feedback:
    Oct 2012
    1,066
Name:	2013-08-02 17.29.44.jpg
ID:	174237 Just a little wore down. haha
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Oct 2012
    1,066
    Anyone know the size or can direct me to a link on ebay?
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    MN
    3,263
    Easy to find... Its the same seal as the E and ES.
    http://www.ebay.com/itm/NOS-Honda-79...f7ca0b&vxp=mtr
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Oct 2012
    1,066
    THANK YOU.. and NO lol its not easy.. at least for me. Seals are like the hardest part for me to find for whatever reason. That would be the decomp lever right? Do you happen to know the camshaft? Or are they both the same seal?
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    MN
    3,263
    You mean the CDI base oil seal under the spark advancer right? Just double checking, its the only seal on the camshaft so im sure thats it... LOL
    If you need that one to i don't recall if its the same size or not, but i think its not, smaller i believe. You can buy a complete set of oil seals for the whole motor for around $20 or less. Would be cheaper than buying two separate seals.
    http://www.ebay.com/itm/Moose-Oil-Se...78b8c3&vxp=mtr
    Oct 2012
    1,066
    haha yup that'd be the one im talking about. Yea I might as well dish out 6 more bucks lol, that first one you sent me was 10 bucks alone. Thank you for the link! I already have brand new seals in the bottom end but will those seals fit my 185 bottom end? Or is the 200 and 185 bottom ends a bit different?
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    MN
    3,263
    They should fit the 185 as well, most of the 185 and 200 parts are interchangeable and the same. The only difference between the years was gasket shapes on them. Those extra seals will come in handy somewhere. I usually just buy the kit for stuff like that nice having spares when the excrement hits the rotating mass....
    Jan 2011
    VA Baby
    225
    KB & Cody.. thanks for this thread!!! I was looking for the same seals!!!
    Safety 3rd
    Oct 2012
    1,066
    Haha no problem.. i dont know why.. but i can't find these seals EVER.. perfect timing to need the seals I guess? =D
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    MN
    3,263
    The decomp lever and camshaft seals are the ones i can't get locally. The rest of them i can usually find similar ones at Napa.
    Just a little tip... When you go to install them fill the back of them with grease, that will keep the spring from popping out when you tap them in. As for tapping in, use a socket that matches the outside diameter of them and drive em in straight! A little grease on the decomp lever and camshaft before sliding them through the seal is a good idea to. I did a few decomp levers that had a worn spot on them, just make sure they are clean and smooth so they don't scratch the new seal and cause a leak all over again. That sucks!! LOL
    Oct 2012
    1,066
    Lol wow.. well thanks for the tip Kb, do i PACK the grease in there or just a little bit, just enough to cover those springs?
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    MN
    3,263
    I pack em full in the back, the grease won't hurt nothing, it will dissolve over time in the oil and just mix in. The added benefit also is the seal is all greasy and when you first start it before the oil gets moving it won't be moving parts on a dry seal, in the case of the camshaft seal for sure!
