Results 1 to 15 of 24
Thread: 1984 Honda atc 200x Little Oil in the Air Box! Problem? Please Help!
    Aug 2013
    Fort Wayne, Indiana
    33
    I just got a '84 200x that has been sitting for a while after the previous owner (my uncle) rebuilt the entire motor. I was taking the lid off the air filter box and checking things out when I found a little bit of oil on the filter and in the box itself. Is this a major problem? Remember I am new to trikes. Thanks in advance for the help!!
    Oct 2012
    WI
    499
    Its probably a foam air filter, foam air filters NEED to be oiled, and some drips off into the airbox.
    Mar 2013
    Central PA
    2,362
    I use spray on oil for foam air filters, would never cause anything like that.
    Maybe someone used any old oil and soaked it and didnt squeeze all the excess out. Just clean it all out, use proper oil and see if it appears again.
    Oct 2012
    Finlayson, Minnesota
    1,066
    x2 ghostv2 said.. even if the rings were gone I can't see oil going all the way back there to that filter. I suppose anything could happen though haha
    1985 Tri Z - Next project!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Check out my feedback:
    Mar 2013
    Central PA
    2,362
    Quote Originally Posted by CodyRosa View Post
    On my 225dx the crank case breather tube goes into a small box then into the air box. When i got it, it was dripping oil everywhere in there. Dont see the point, but its possible. I dont see it happening on a 200x though.
    Aug 2013
    Fort Wayne, Indiana
    33
    Thanks so much for the info. I will just clean it and keep an eye out!
    Jul 2013
    Florida
    110
    Check the oil level. If its too high, the oil will be routed into the air box. Also smell the oil, if it smells like gas the carb float is stuck and leaking gas into the crankcase through the piston.
    Mar 2013
    Central PA
    2,362
    Quote Originally Posted by GunsShooting View Post
    Im completely rebuilding the bike so im sure if there was a problem itll end up being fixed. I bought it cheap and then it died like a week later. I knew the engine needed rebuilt when i got it anyways.
    Quote Originally Posted by irishfan84n View Post
    No problem. Just next time you got some spare change check out that spray on foam air filter oil. I think the one i got is Klotz, $7.96 online, i got mine at the local shop. Its red colored so you can see any spots you missed.
    Oct 2012
    1,066
    oh on the 200x the breather goes into the airbox? haha i've never routed any of my breathers to my airbox
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Aug 2013
    Fort Wayne, Indiana
    33
    That could be, because it has sat for a while after the rebuild and my uncle said that I would have to more that likely rebuild the carb. Also, I will make sure I get some of that air filter oil spray.
    Aug 2013
    Fort Wayne, Indiana
    33
    So you are saying that you can just stick a cone air filter on the side of the carb and not use the airbox at all? I don't plan to do much bogging or anything with this, so that might be a better option, giving it is possible. Thanks
    Jun 2012
    Aberdeen WA USA
    139
    Not a good idea open air filters get messed up real quickly the air box prevents a lot of dirt from getting to the filter.
    Mar 2013
    Central PA
    2,362
    Any water, mud, anything that gets splashed up on there will effect performance. Then you also have to rejet your carb. If anything, take the air box lid off for a little extra boostand get a new filter. I personally would leave everything alone. Your trike will last longer with the closed intake system intact. Plus i like to take mine though the water so i leave it go. Plus with a pod filter you would have to clean it after every ride if you ride through all the stuff i do. Mud, coal dust, etc.
    No, we were talking about a 225dx.
    Mar 2013
    Minnesota
    441
    Yes you can
    ~~ATC's Currently Owned~~
    1983 Honda 200x - Main ATC
    1985 Honda 200x - Parts Bike
    ~~ATC's Previously Owned~~
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1983 Kawasaki klt 200a
    1986 Honda 200s
    ~~Other Toys Owned~~
    2012 Pro R 800
    1993 Polaris Indy 500
    2004 Yamaha 125
    1990 Thunder Kart - 250CC
    2001 Yamaha Blaster - 240kit, aftermarket exhaust, power reeds
    Aug 2013
    Fort Wayne, Indiana
    33
    Thank you guys soo much for the info and input, I think will just stick with the stock filter system. Sounds like the easiest and best thing for the trike. I do have to get a new air filter, since the foam one I have is flaking apart because it is so old. I also had a question about what to clean the long carb boot(air box boot) with?
