Results 1 to 7 of 7
Thread: will a 1980 110 coil work with a 1977 atc 90
    Jul 2013
    mo
    327
    I've spent all day with it .have voltage at generatr and even changed to points from motor that ran . Coil is good and tested . Schematics for coil are different . So I'm guessing that why still no spark . Can the hook up to the capacitor be modified to work . Hhhhheeelllpp.
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    6,784
    Yes a 79/80 110 coil will work .
    Jul 2013
    mo
    327
    So the black/white wire wil be tied together with both blacks and points wire. Green goes to what. Yellow to yellow.???
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    6,784
    Green is ground and the yellow is for the lights .
    Jul 2013
    mo
    327
    Thanks man. After knowing that the coil ahould work I went back at it and swapped the stator out. And BBAAAAMMMM she was off and runnin. I guess I just need conformation that the coil will work that it had to be the stator. Thanks again.
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Cold Lake, Alberta, Canada
    3,013
    Love those rawhides and fork extensions! Looks a little like the "Fugly" project I'm just finishing http://www.3wheelerworld.com/showthr...uot-Fugly-quot . That was also a $150 machine. Do you have a vid of it running?
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Jul 2013
    mo
    327
    I will shortly plan on a repaint . Just ebayed some axle bearings chain and brakes . And she will he hot for the trails. Ya I love the look of these old rawhides.
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
