Results 1 to 11 of 11
Thread: 250r not running to potential.
    Jul 2013
    croghan NY
    8
    my 85 250r is bogging out and not running the way it should. I think it has to do with the jetting but I could be wrong. I'm running a 145 main jet, my clip is in the middle and my air skrew is out 2 turns. my modifications consist of:
    69mm wiseco piston
    stroker crank with cylinder spacer
    boyeson reeds
    fmf pipe "esr pipe coming soon"
    esr air box delete kit
    and I live in upstate New York.
    I'm running amsoil mixed 32:1
    any help would be greatly appreciated!
    Jun 2012
    Aberdeen WA USA
    139
    My brother had that problem with his 250r he bought last weekend and when he took it apart he discovered it had a needle out of a 660 raptor stuck in there. (Waiting for him to come up this weekend to see how they got it in there.)
    Jul 2013
    croghan NY
    8
    I ordered a carb rebuild kit and replaced everything
    Blossvale NY
    4,563
    Hey there smonnat_1, welcome from a fellow upstater!
    Please don't be offended if you have already covered the basics, but I have to ask to be sure.
    First thing you need to do is make sure you have fresh fuel in the tank and it is adequately supplying the carb. Next thing is FULLY disassemble the carb and thoroughly clean it, top to bottom, inside and out, every piece, every jet and every fuel and air passage in the carb body.
    Once done cleaning, check float height and adjust as necessary. If you can tell me what carb you have on your R I can give you the float height spec.
    That would be the first couple steps in addressing your poorly performing R. Do those things if you have not yet done them and report back..
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Jul 2013
    croghan NY
    8
    hey RIDE-RED 250r, I was tinkering with the jets tonight. bumped up to a 160 main jet and it runs decent but it's not really taking off when the power band kicks in. it just keeps cutting out
    Oct 2012
    Finlayson, Minnesota
    1,066
    Hello Smonnat! Just curious if you've done the most simplest thing.. have you checked your spark plug yet? How old is this plug? The simple change of an old plug to a new can do wonders. It could fix your problem without needing to jet or could just run better in general.
    1985 Tri Z - Next project!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Check out my feedback:
    Carthage NY 250r rules
    2,355
    Welcome neighbor Im in Carthage NY .Do you have another coil to try.My 85 250r had similar trouble couple years ago .It would start fine idle fine anything over like 1/4 throttle and it would sputter .I messed with the carb ,plugs ,fuel mixture,airfilter,Finaly I decided to try another coil and it was like a whole new trike.There are some atv drags at Harrisville this weekend you should come.Im running two of my aircooled Rs.
    250r rules
    Jul 2013
    croghan NY
    8
    jeez Carthage is pretty close. I have to work Saturday so i don't know if I'll be able to make it to the drags but you should PM me your number. I have a camp on the Texas road close to Carthage and live just outside of croghan. we have to meet up and go riding sometime lol
    2,355
    I ride the trails and power lines in that area.Riding together sounds awsome.
    250r rules
    Sep 2013
    Ohio
    22
    check your whole wiring harness for shorts to ground.. my buddy had the same prob with his 85' atc 250r... he changed his whole harness just for sh**s and giggles and whallah!!, back to throwin roost immediately.. lol.. good luck..
    Sep 2013
    Ohio
    22
    also the stock jetting for the 34mm roundslide is as follows
    main # 142
    pilot/slow #52
    this is straight out of the honda service manual....
    since your engine has a 3mm overbore, these numbers are not what u should be running,,, they are just a basis for u to start from.. hope u get it fixed bud... happy ridin
