Results 1 to 8 of 8
Thread: 200x questions...
    Jul 2013
    Medford Oregon
    103
    200x questions...
    So I was given a 86 200x frame.... I have a spare 86 200x motor but no mounts, intake, carb, kicker, shifter, cdi, coil,,,, nothing.... I have lots of left over 1st gen 200x parts, from the junkyard save/build me and my buddy did.... Will any of the 1st gen 200x parts fit the 2nd gen X frame and motor or will the 2nd gen motor fit in a 1st gen frame
    79 atc70 "builder bike"
    85 atc70 "mostly stock cruiser"
    83 250r "regular ride"
    86 200x "the woman's bike"
    85 tecate "red bike, resurrected"
    85 tecate "green bike, custom"
    Chromed Joker w/Honda 110 w/ hi/low
    YEAH IM JUST A LITTLE ADDICTED
    feed back at http://www.3wheelerworld.com/showthr...r-ATC-ADDICTED
    The others
    98 kx80 "the boys ride"
    ?? Baja 90cc wilderness "daughter cruiser"
    Oct 2012
    Finlayson, Minnesota
    1,066
    1st and 2nd gen are completely different. I think theres like 1 or 2 parts that actually switch over.. like maybe the front hub?
    Just so you know theres probably a 100 of these threads.. try using the search button as i'm sure someone lists everything that can/cant be used.
    Goodluck
    1985 Tri Z - Next project!
    1982 250r - Sold
    1983 Auto X - Sold
    1984 Auto X - Sold
    1985 200M - Sold
    1985 YTM 125 - Sold
    1985 185 - Sold
    1984 185 - Sold
    Check out my feedback:
    Mar 2013
    Wausau, WI
    147
    No, no they won't
    Apr 2010
    Indian Falls, NY
    1,289
    As said nothing changes over. The '86-'87s are awesome and I want one pretty bad but parts are a bit harder to find and more expensive than the first gens.
    Slidell, LA
    4,738
    Not true. My bike is living proof. The 86-87 front hub does change over if you use the first gen spacers, and axle. Look at my bike, that is a 86-87 200x hub...why did I use it? Because I can now use Xowner's 10 inch wheel. Like Cody Rosa said, do a search, you will find countless threads on this subject.
    Mar 2007
    Texas
    5,045
    ^ i think they are talking abotu engines and such not every part in general.
    ________________
    https://www.mikesatvfix.com
    Apr 2010
    Indian Falls, NY
    1,289
    I should have said almost nothing changes over, my bad.
    Oct 2008
    Reedsport Oregon
    856
    2nd generation better?
    no way ive owned both and yes the 2nd gen performs better all around and looks awesome but it flat out did not hold up as good as the first gen x did, waaay more motor problems and frame problems
    i kept the first gen
